hay folks finally getting around to replacing the rear end in my lincoln town car and am having a hard time finding someplace that sells refurbished rear ends, gears barrings etc..any ideas? thanks Bradford
1989 lincoln town car rear end replacement
Generally no one sells "refurbished" rear ends whole. Your best bet is to rebuild what you have. The things that most commonly wear out, other than suspension bushings, are the bearings which are all available from rockauto, summit racing, or your local parts store. Sometimes the axle shafts are also damaged because the bearing rides on them, so you get scoring or pitting at the end of the axle shaft.
yep, all the parts can be had. Its just a matter of emptying out the housing and replacing the bits in there. Now would be the time to add a traction lock carrier, rear discs, and consider changing the rear gear ratio if you had any thoughts on doing so.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postyep, all the parts can be had. Its just a matter of emptying out the housing and replacing the bits in there. Now would be the time to add a traction lock carrier, rear discs, and consider changing the rear gear ratio if you had any thoughts on doing so.
That all depends on what you want from the car. Performance? snow traction? Highway mileage? Are you modifying the engine? If you just want it to behave like factory, don't worry about it.
if it's not a trak-lok (limited slip/posi) already, you should consider putting that in. That and lower rear gears, probably 3.27-4.10 depending on how much you care about highway fuel economy. 3.27 is what I'm going to because I want to still do ok on gas at 80mph, but lots of guys run 3.73 or even 4.10 gears and don't regret it. All about the balance between keeping the RPM's low at high speed and getting that kick off the line.
300K? Nice. Here's to 300K more!
it may be a 3.27 already. Towncars had a 3.08 or 3.27 usually. I'd go at least 3.55, but thats just my 2 cents.86 Lincoln Town Car (Galactica).
I love the 3.55s in my vic and 88. the Mark has 4.10s and that runs into speedo calibration issues (it marks about 10 low at 70).
thanks guys have made my parts list for the rear end so it and the trans rebuild are planned..while everyone is in a rear end kind of mood noticed on one thread that someone had placed larger breaks on the rear end..searched the thread and didn't really see anything..could someone clue me in on this also..I want to keep my finned wheels if possible
