1978 Caprice, the new on-going project! (Yes, I'm still alive!)
    That be a GTX sir, a 1970 if my eyes serve me correctly. It's a 2dr.
    Edit: Nope, it's a four door Belvedere with GTX stuff.
      What's on the right side of the speedo? Looks like a perfect place for a in dash tach. Maybe a combo oil pressure/temp/volt on the other?
        should be some warning lights in the segments and a center with nothing in it IIRC, though I don't think it's a full 2 inches to fit a mini tach, but it might be.
          It's a lot of my dummy lights lol.
          Sent from my VS985 4G using Tapatalk
            Interesting, what are they?
              I know there's seat belt and brakes, I'd like to say oil pressure, low fuel, battery, engine temp... Not sure about the last one though!
              I painted the HVAC bezel today, the wood trim looked way out of place. Gloss black flows 10x better...
                <----- is jealous. Very nice work that you've done to the car.
                  Short video action today!
                  https://vimeo.com/182251220
                    Sounds great!
                    '93 T-bird
                    '03 Silverado ECSB
                    Missed:
                    '88 Mark VII
                    '86 CV
                      Thanks man!
                      The past few days I've been scraping, painting, painting... And painting the underside of the car. It has a lot of odd rust spots I'm trying to get under control, or at least slow down. I'll post a pic of the back end of the car later, that's where 90% of the work needed done.
                      I did do a little more painting on the front end though! Unlike the Crown Vics, the headlamp bezels are removable as a seperate piece on my Caprice. Goodbye oxidized chrome, hello gloss black!
                        I realize not everyone digs the black headlight trim but its worlds better than crappy peeling "chrome" IMO. I fixed the bumpers on my first 2 cars with black paint. Rusty chrome looks horrible.
                          Black bumpers do look good on the right cars though!
                          I did get the underside of the trunk finished, it's not perfect and not a permanent fix, but it is 10x better. I did find some rust holes I didn't know I had before though...
                            I really need to work on updating this as I do things! I pulled all the plugs back in September, no oil on them at all, so I'm quite impressed! I also found that my alternator plug was rigged up to say the least, so I repaired it properly.
                            I also did a little more rust repair, as I went to replace the trunk seal and discovered a few areas of rust hiding behind it. I also finally got around to scraping, sanding and painting the area behind the license plate. My dash finally got a crack as well, so I tossed a velour cover on it quick to keep it from worsening.
                            Right before I put it away, which was done Friday evening when it was still 70 degrees, I used an Eagle1 polishing mitt on all of the glass and chrome, it has never looked that good before!
                            Now she rests until Spring, once again...
                              Cool, a tre-oh-five that doesn't have shitty valve guides/stem seals. Someone opted for tilt wheel with that? Neat.
                                This car is optioned very strangely. It's a very low optioned Classic model, it doesn't even have rear defrost. However it has big front and rear sway bars and underbody braces... At the same time, it only has a 7.5 rear with 2.41's. Then it has power locks and tilt wheel.
                                It's like a clusterfudge of options...
