Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
Thread: 84 X 1/9 Bertone
  1. #21
    Birdsboro PA.
    17,153
    i built a model of that car when i was a teenager
  2. #22
    Apr 2006
    MI
    3,805
    Been working on the X a bit of paint. Engine stabilizer annd front cover to match the plenum. Also been cleaning dirt off the engine. Looks like oily dirt from dirt roads from were I IN northen Indiana were here were a lot of dirt roads.
ID:	41639 Click image for larger version.
    Pink pearl base coat
ID:	41641 Click image for larger version.
ID:	41643 Candy red and clear coats
  3. #23
    whiskey runner murphmobile2's Avatar
    Jan 2007
    Troy, Ohio
    1,696
    That is sexy!!
  4. #24
    Apr 2006
    MI
    3,805
    Been working on finishing up the complete brake and clutch hydraulic systems when its raining and cant work on the Bird. Had to remove the drivers seat remove steering wheel and part of the shaft to get at and remove the steering column master brake and clutch cylinders. The leakage from the brake master turned the carpet from red to pink and white.
