91 Grand Marq shock replacement
    What's up guys? So I'm replacing the rear shocks in my little brother's 91 GM after work today and was wondering how to get to the top bolt on the shocks. I had the car up in the air a week ago but I wasn't able to figure out how to get to it. can anyone help me out?
    2010 Toyota Camry "Traveller II "
    54,xxx miles. New daily driver
    2001 Lincoln Town Car Signature "Leroy"
    rear cats deleted, 2" h pipe, dual 8" cherry bomb glasspacks
    114k miles. Sold to my coworker.
    1998 Toyota Camry "Traveller"
    Dead and sold.
    Most say ratcheting combination wrench, I say reciprocating saw with a 12" metal blade and cut that sucker off. Watch the fuel lines on the drivers side. Good time to change the springs too, and the rubber line for the rear brakes
    Pete
      What Pete said. I used a Drimmel with one of the tile cutting bits to cut mine off. I also used the flex shaft on the drimmel to get extra reach. It was a piece of cake after cutting the nut off.
        Top shock nuts? Aint nobody got time fo dat! +1 for what pete said. I use the longest Milwaukee torch blade. Nice and quick.
          I was too skeered to use the saw... but then I had no rust issues. box end wrench on the top and remove the bottom bolt and then wrench the hex top of the shroud to loosen the nut up top.
            Lucky! 25 years in the rust belt surrounded by water made mine look like they came off the Titanic.
              Vise grips just below the lower and let it spin against the frame, and then loosen it with a wrench by reaching up from underneath.
              Or, make (or buy) one of these and wrench it loose from the wheel well, you don't even need to remove the wheel, just let it hang.
              Alex.
