This all happened about a week ago. I filled up Ebyt with about half a tank of ethanol free 87 octane gas. I didn't know what kind of gas was in there beforehand- I'm assuming since it was a daily driven MI car that it was something with ethanol, likely 87 octane gas. I also noticed that when I tried to pump the ethanol free gas, I had to apply a certain amount of trigger pressure to make it pump. (If I did squeeze full pressure, it would just go "CLICK!" and stop pumping the gas within half a second.).
I pulled out of the station to begin the trip home. Within a couple minutes, the check engine light came on. I knew better than to ignore it, so I looked for a parking lot to pull over in (I was on a 2 lane road with no shoulder, go figure). By the time I found one, the light turned off, and stayed off ever since. She was making some weird sounds until that point though. Didn't sound the same under acceleration either. But she smoothed out, and kept on chuggin' along. The check engine light turned off, and all seemed normal.
Perhaps the car just had to burn off the crappy ethanol gas before running fine again? What should I do in the future when I want to switch to ethanol free gas?
