So I've got an electrical-wise stock 351W/variable venturi car with the starter solenoid on the fender. I bought one of the newer starters (asked for a 91 crown vic 5.0 one) that's smaller and has the solenoid on the starter.
I've pretty much got it as far as wiring the starter itself. run the start signal wire to the small terminal on the starter, run the starter cable basically directly from the battery to the big terminal on the starter.
What should I do with the cables that are currently on the positive terminal of the fender-mount starter solenoid? It's the positive cables for pretty much everything on the car. I think there are 5 actual cables. I now have nowhere to hook them.
Suggestions/ideas I've gotten so far:
1. quick and dirty; put all those cables and the starter cable together on a bolt, crank a nut down on it, and cover it in intense amounts of electrical tape or some other insulator
2. maybe overly complicated; mount a junction box where the solenoid is now, and wire each of the existing wires into their own spot. This sounds pretty time consuming, and like a mess of wiring to get that and a decent sized starter cable going to the positive battery terminal.
Anyone have a better solution?
