Larisa "1982 Lincoln Continental Mark VI Bill Blass 2-Door
    Originally posted by MattsLincoln View Post
    It's time for a motor swap in a few weeks . she will be off the road when the new motor is ready to go in, as of now to 260,000 mile 302 thats tired as hell will be running and making its last appearance at scottfest 2015.
    What engine are you putting into it?
      Throw a lower axle ratio in it, you can squeeze more life out of it. That's what I'll do with my Lincoln, 3.08 to 4.10 for the illusion of power.
        it will be getting a Explorer 5.0, with a cobra cam, D9S ECM. im going for P Heads.
          P heads and speed density don't tend to play nice together. Too much airflow for it to handle unless you have it tuned.
            i think it will work. john said the reason why his was acting up is because of his 02 sensors being plugged in the wrong way making it go into a continuous loop. 86VickyLX please chime in with your thoughts too. let me know what can be done. if needed i will grab a A9P ECM and go mass air.
              Thought the O2 sensors were "keyed" so there is only one way to plug them in???
                I don't know the sense in keeping speed density when upgrading a motor... D9S or any speed density being used for performance, is junk. If you want an A9S, good luck spending 180$ on an ECM, with small gains.
                Did you ever fix your axle?
                Originally posted by SVT98t
                  Speed Density isn't the problem. The problem is finding someone that will tune it. It's more time consuming and people are lazy. The D9S keeps cruise control on 88+ panthers without having to do a bunch of wiring. Since his is an 82, it should have a separate cruise module, so mass air with an A9P/M/T shouldn't be much of an issue there. And that will allow tuning with most shops that aren't stuck up/under-equipped OBD-II only places.
                    oxy sensors are identical left and right. Very easy to mix the wiring up if you aren't careful. They only plug into the connector one way though.
                    Dunno, my car ran horribly lean with ported E7 heads and the Explorer intake. I ran it on a dyno once and it was somewhere around 18:1, which is in the "melt your pistons" realm. P heads will move similar amounts of air. I know it could have been tuned out, but back to finding someone who can and will do it. Mass air is more easily understood by most, and its generally less bitchy about engine mods. I know my current setup would not work with S-D, but it runs quite fine with an un-tuned stock mass air setup. I'm sure it could be better, but at the moment it doesn't idle stupidly, ping, rattle, stumble, or have any other generally obnoxious habits, and for the moment that is good enough.
                      There's really nothing wrong with SD, and some people actually prefer it. P heads and SD seem to be hit and miss on these cars. I had one of the few that ran flawlessly, but it comes down to a variety of things.
                        Time for a big update, motor swap is happening next week, got pics so far, head are at the machine shop getting 3 broken lower intake bolts out, and a valve job, with New Trickflow Valve Springs. Im currently cleaning the top of the pistons(bathroom cleaner works amazing), and then degreasing the block and prepping it for paint, got a shit load of new parts for this engine looking forward to the build.
ID:	1278436Click image for larger version
ID:	1278437Click image for larger version
ID:	1278438Click image for larger version
ID:	1278439Click image for larger version
ID:	1278440Click image for larger version
ID:	1278441Click image for larger version
ID:	1278442Click image for larger version
                          Cleaned up nice. Just make sure you get all of that out of there, and put some oil down the cylinders to flush out any residue that got past the rings. You don't want anything rusting the cylinders while its apart.
                            Wait a second.. You're not rebuilding it...? Ba-what?
                            Wasn't that the whole plan.. A 'new' motor?
                              That must be the "new" (Exploder) motor, based on the mounts and oil filter adapter at least. But darn she looks nasty on the outside, any estimate on how many miles were on that thing? Mileage unknown and considering the overall shape of it, I'd have at the very least spun the oil pump with a drill to see what oil pressure she's capable of.
                                used mixed mystery motors usually run decent (89 vic, 92 gmq) as long as the bottom end isn't real sloppy.
                                loose motors make power............somewhere at my parents place i have a worn out 302 that i had given to me, guy claimed it was running low 13's in a mustang notch.
