Larisa "1982 Lincoln Continental Mark VI Bill Blass 2-Door
    Looking good dude, especially with all the frustration you dealt with.
      Originally posted by His Royal Ghostliness View Post
      Needs a MSD coil. Cause color coordination!
      I agree eventually i will replace the cap and coil with an MSD one so colors match, wonder if msd makes a red ford starter solenoid cause mine is blue just like the coil.
        I think they do. I'd honestly just paint it cause MSD don't do diddly dick unless we're talking about high rev applications.
          Just don't forget to turn the light off. That would be a good source of a dead battery for no obvious reason.
            I believe the slightly higher output helped if you like to use platinum plugs. Yes?
              perhaps, though I find mine runs better with boring copper plugs.
                Nice Matt. I like the underhood light.
                  I wouldn't mind having one of those lights. I'd be able to mount it in a similar to stock spot.
                  Can't put it in the center, since that's where the engine hits the hood....
                    Logan i will definitely get you one, i will be collecting everyone i see. They work very well
                      Yeah get me one as well Matt
                        ok so i will start gathering them junkyard run in 2 weeks there $10 each, i have 3 people that want one so far correct ? Logan, Gabe, and David ? John Sexton acquired one earlier this week for him.
                          I got the ford version. This David don't need one. Thanks though Matt.
                            ok so just logan and gabe.
                              If you come across another, I would be glad to have one.
                              Thanks,
                              jay
                                UPDATE: Finally did my mod and was able to use red lighting gel to change the color of my digital readout, works good but fuel gauge and message center display are hard to read due to the displays not being as bright as the speedometer reading, this will be all fixed once i find an 89 town car digital cluster as they have updated stuff on the circuit board and its display is much brighter than early digital dash displays.
ID:	1280300Click image for larger version
ID:	1280301Click image for larger version
