Larisa "1982 Lincoln Continental Mark VI Bill Blass 2-Door
    ah fuck, guess i will be using the stock control arms for now and just get new bushings for them, how do you remove the upper control arms ?
      the two bolts on the frame and the upper ball joint from the knuckle... or you can try changing the bushings ON the car using a control arm bushing press (it's smaller than the ball joint press but the same idea).
        Could just do 96-97 brakes.
          I've got a set of upper and lower control arms that are on my old frame. Both are loaded with brand new ball joints and ES bushings. You could bolt them on and go. They're 97 arms so all you'd need is spindles for a BB swap. Which I have one of.
          Also, no arms were tubular.
            How much you asking for the pair of upper control arms ? I was told only 92-95 will work with the big brake spindles for a 98-02.
            Also curious on price for the lower control arms might as well do all of them. Since my lowers are probably shot too
              PM me on here or FB, I actually believe that they are indeed 94 arms, I tossed my 97 set since I was going to have to do too much work on them.
                97 arms work if you put the 80s shaft through them. That turns it into an early 90s arm. If he had it bolted on a box, it'll bolt to another box.
                  you can make the 96-02 upper arms work by installing the shafts from the stamped upper arms..........i have done it a few times in the past...................92-94 arms def easier to use tho.
                    This is what I was doing. Then I was like "This is dumb and an insane waste of time" tossed them and got a 94 set.
                      More Updates: Replaced my headlights with hella h4 conversion lights, also relayed my headlights, after doing so there is now this annoying 5 second delay and an autolamp issue.
                      Issue 1: When autolamp is active the headlight doors refuse to shut after the headlights go off(sometimes they will shut like there suppose too), though if i shut off autolamp and use the headlight switch to manually turn them on and off the doors will shut all the time.
                      Issue 2: Ever since i relayed the headlights there has been this stupid delay going on when the headlight switch is off, the headlights will stay on for 5 seconds then shut off, then 3 secs later the headlight doors will shut, before relaying the system, the light would shut off immediatley wen the headlight switch was off and the doors would go down immediately too.
                      more news, heater core has a leak in it somewhere its small though, bypassing the heater core since this car does not see winters, the blower motor is weak in the car so i probably need either a new blower motor resistor or blower motor.
                      heres pics and links to vids.
                      hella lights on driver side, factory on passenger side
                      with all hella lights in before being relayed, and a pic of the headlight relays
ID:	1280127Click image for larger version
ID:	1280129Click image for larger version
                      the new engine running
                      https://www.facebook.com/mattgmantik...7826429046364/
                      first start up of the new engine
                      https://www.facebook.com/xNightShado...2127576473440/
                        running is good.
                          Pull the blower out and see if it has a bunch of shit packed into the fins. Had that problem on the Mark VII.
                          Autolamp might rely on some sort of load sensing thing to operate a solenoid to open and close the lights. The relays would remove the load and it may be confused now.
                            More Updates and Pics, installed a manual retractable hood light from a 90's chevy/gmc C/K series full size pickup truck, works alot better than the automatic ones imo, hasan on/off lever for the bulb. Also pics of the engine and driving vids.
                            videos
                            https://www.facebook.com/mattgmantik...5573274938346/
                            https://www.facebook.com/mattgmantik...5601394935534/
                            https://www.facebook.com/mattgmantik...5601468268860/
                            Pics
ID:	1280216Click image for larger version
ID:	1280217Click image for larger version
ID:	1280218Click image for larger version
ID:	1280219Click image for larger version
ID:	1280220Click image for larger version
                              very nice Matt
                                Needs a MSD coil. Cause color coordination!
