Page 3 of 15 FirstFirst 1234513 ... LastLast
Results 41 to 60 of 287
Thread: Larisa "1982 Lincoln Continental Mark VI Bill Blass 2-Door
  1. #41
    23,089
    my Mark was doing the same thing (shudder/vibration on deceleration from speed)... apparently the TL carrier and spider gears that were in that rear axle were chewing themselves into oblivion. Probably a rear axle issue if it's not u-joints.
    As for the RPM bouncing thing, if the connection to the MAF is flaky, it'll do that.
  2. #42
    Livin', Lovin', Lincoln Midnight Drifter's Avatar
    Sep 2011
    Monroe, NJ
    424
    Glad to see your Lincoln still going strong! Save for the computer gremlins, but I'm sure you'll work around em
    1997 Lincoln Town Car Executive Series - Charlene
    Saved from a tragic fate, planned mild restoration. Now with working heat, perfect for the cold winter!
  3. #43
    Fastest Boxes In South Jersey 86VickyLX's Avatar
    Jan 2007
    Westmont, New Jersey
    10,427
    Glad to hear it's still running strong. As strong as that tired 302 can be that is.
  4. #44
    I post a lot... chitownvic's Avatar
    Jun 2008
    Chicago, IL
    2,646
    U joints got my vote on the shudder.
  5. #45
    Learning The Ways Of Box Panthers MattsLincoln's Avatar
    Jan 2010
    Shavertown, PA
    2,535
    It's time for a motor swap in a few weeks . she will be off the road when the new motor is ready to go in, as of now to 260,000 mile 302 thats tired as hell will be running and making its last appearance at scottfest 2015.
  6. #46
    Presidential Ride L1011tristar17's Avatar
    Sep 2012
    Charlotte, NC
    900
    Quote Originally Posted by MattsLincoln View Post
    What engine are you putting into it?
    1989 Lincoln Town Car 249k miles, current project car
    2018 Toyota Tacoma bone stock, daily driver
  7. #47
    I post a lot... 88Vic's Avatar
    Olathe, Kansas
    1,651
    Throw a lower axle ratio in it, you can squeeze more life out of it. That's what I'll do with my Lincoln, 3.08 to 4.10 for the illusion of power.
  8. #48
    Jan 2010
    Shavertown, PA
    2,535
    Quote Originally Posted by L1011tristar17 View Post
    it will be getting a Explorer 5.0, with a cobra cam, D9S ECM. im going for P Heads.
  9. #49
    41,317
    P heads and speed density don't tend to play nice together. Too much airflow for it to handle unless you have it tuned.
  10. #50
    Jan 2010
    Shavertown, PA
    2,535
    i think it will work. john said the reason why his was acting up is because of his 02 sensors being plugged in the wrong way making it go into a continuous loop. 86VickyLX please chime in with your thoughts too. let me know what can be done. if needed i will grab a A9P ECM and go mass air.
  11. #51
    Proud Owner Of A 1987 Mercury Grand Marquis! miamibob's Avatar
    Apr 2011
    South East Florida
    4,478
    Thought the O2 sensors were "keyed" so there is only one way to plug them in???
  12. #52
    Do a burnout, pussy. Bobcat's Avatar
    Jan 2013
    West Granby, CT
    1,271
    I don't know the sense in keeping speed density when upgrading a motor... D9S or any speed density being used for performance, is junk. If you want an A9S, good luck spending 180$ on an ECM, with small gains.
    Did you ever fix your axle?
    Quote Originally Posted by SVT98t View Post
    23,089
    Speed Density isn't the problem. The problem is finding someone that will tune it. It's more time consuming and people are lazy. The D9S keeps cruise control on 88+ panthers without having to do a bunch of wiring. Since his is an 82, it should have a separate cruise module, so mass air with an A9P/M/T shouldn't be much of an issue there. And that will allow tuning with most shops that aren't stuck up/under-equipped OBD-II only places.
  14. #54
    41,317
    Quote Originally Posted by miamibob View Post
    oxy sensors are identical left and right. Very easy to mix the wiring up if you aren't careful. They only plug into the connector one way though.
    Dunno, my car ran horribly lean with ported E7 heads and the Explorer intake. I ran it on a dyno once and it was somewhere around 18:1, which is in the "melt your pistons" realm. P heads will move similar amounts of air. I know it could have been tuned out, but back to finding someone who can and will do it. Mass air is more easily understood by most, and its generally less bitchy about engine mods. I know my current setup would not work with S-D, but it runs quite fine with an un-tuned stock mass air setup. I'm sure it could be better, but at the moment it doesn't idle stupidly, ping, rattle, stumble, or have any other generally obnoxious habits, and for the moment that is good enough.
  15. #55
    GMN = life pantera77's Avatar
    Oct 2008
    Buffalo, NY
    5,066
    Quote Originally Posted by Bobcat View Post
    There's really nothing wrong with SD, and some people actually prefer it. P heads and SD seem to be hit and miss on these cars. I had one of the few that ran flawlessly, but it comes down to a variety of things.
  16. #56
    Jan 2010
    Shavertown, PA
    2,535
    Time for a big update, motor swap is happening next week, got pics so far, head are at the machine shop getting 3 broken lower intake bolts out, and a valve job, with New Trickflow Valve Springs. Im currently cleaning the top of the pistons(bathroom cleaner works amazing), and then degreasing the block and prepping it for paint, got a shit load of new parts for this engine looking forward to the build.
ID:	43935Click image for larger version.
ID:	43936Click image for larger version.
ID:	43937Click image for larger version.
ID:	43938Click image for larger version.
ID:	43939Click image for larger version.
ID:	43940Click image for larger version.
ID:	43941Click image for larger version.
  17. #57
    41,317
    Cleaned up nice. Just make sure you get all of that out of there, and put some oil down the cylinders to flush out any residue that got past the rings. You don't want anything rusting the cylinders while its apart.
  18. #58
    Jan 2013
    West Granby, CT
    1,271
    Wait a second.. You're not rebuilding it...? Ba-what?
    Wasn't that the whole plan.. A 'new' motor?
    Feb 2015
    3,125
    That must be the "new" (Exploder) motor, based on the mounts and oil filter adapter at least. But darn she looks nasty on the outside, any estimate on how many miles were on that thing? Mileage unknown and considering the overall shape of it, I'd have at the very least spun the oil pump with a drill to see what oil pressure she's capable of.
  20. #60
    Birdsboro PA.
    17,847
    used mixed mystery motors usually run decent (89 vic, 92 gmq) as long as the bottom end isn't real sloppy.
    loose motors make power............somewhere at my parents place i have a worn out 302 that i had given to me, guy claimed it was running low 13's in a mustang notch.
Tags for this Thread
