Page 18 of 18 FirstFirst ... 8161718
Results 341 to 360 of 360
Thread: My 2004 Mercedes Benz E320 aka The Benz
  1. #341
    Sep 2008
    Whitestone, NY
    18,499
    Yeah...so this happened.
    Havent used the car since Tuesday. Pulled it in front of the house today to wash it and once done parked it back in its spot.
    Checked on it later in the day to find this all out.
    All I can say is THANK GOD it did not happen while driving.
    Had to put on the spare to even be able to drive it into the backyard to disassemble it.
    New front struts and springs for the front and new springs and shocks for the rear on all on the way.
  2. #342
    Nov 2014
    Evans, GA
    1,392
    Yikes. That could have been real bad.
    Any idea how the spring just sheared like that? Don't see any rust that would indicate fracturing prior.
    -1987 Grand Marquis Colony Park LS (325K Miles) - April 2017 POTM Winner
  3. #343
    Sep 2008
    Whitestone, NY
    18,499
    No idear. Just as perplexed as you.
  4. #344
    Mar 2006
    Bedford, VA
    5,024
    So it was just sitting there in the driveway when the epic fail happened? Holy smokes.
    1988 Crown Vic Wagon - daily
  5. #345
    GMN Regular Giraffe's Avatar
    Jan 2016
    Wichita Falls, TX
    822
    Most likely a manufacturing defect.
    óJohn
    1990 Mercury Grand Marquis LS (POTM March 2017 & May 2019)
  6. #346
    I post a lot...
    Apr 2010
    Southern NJ
    2,545
    A defect that took 15 years to show up?
    2017 Buick Enclave 3.6 (Burgundy/Beige)
    2017 Hyundai Elantra SE w/tech (Silver/Grey)
    Past Panthers
    Quote Originally Posted by Lincolnmania View Post
  7. #347
    Sep 2008
    Whitestone, NY
    18,499
    Yes.
    Quote Originally Posted by Giraffe View Post
    Quote Originally Posted by tjc78 View Post
    This was my initial thought. Bizarre for a defect to show up this many years later.
  8. #348
    Jan 2016
    Wichita Falls, TX
    822
    Not all manufacturing defects will lead to immediate failure. Difficult to tell from the picture, but I'll bet you'd find some stress cracking if you took a really close up picture of where it broke.
    Call it a defect helped along by daily use.
    óJohn
  9. #349
    Sep 2008
    Whitestone, NY
    18,499
    Benzo is back in action. Front struts and springs replaced and slapped in new rear shocks. Still waiting on one last rear spring, though I doubt I will change them out. Attempted to remove the necessary bits in order to get the spring out of the lower a arm and its a bear. One honkin' 12mm hex headed bolt through the knuckle and lower a arm to a 21 mm nut just is seized in place. Rear springs are most likely staying put.
  10. #350
    37,611
    probably just a fatigue failure over time. Springs move a lot and eventually if you bend stuff it'll work harden and crack. Lucky it happened when and where it did.
  11. #351
    Mar 2010
    Lewisville, TX
    20,963
    potholes in Dave's area are notorious by nature.
  12. #352
    Sep 2008
    Whitestone, NY
    18,499
    Made a last ditch attempt at replacing the rear coil springs by following this video below:
    Fail.
    The bolt securing the lower a arm is seized inside the bushing.
    I am also glad I measure the toe ahead of time as I had a suspicion there was a cam for toe adjustment on that toe arms bracket to the subframe..... and I was right. I wish the damn video mentioned you would need to get an alignment afterwords.
    The internet...cant trust it.
    No worries though I just set the toe to how it was before and all is well again. Got to use my toe plates as well as my turn plates (wheel on top of plates that turn and allows you to make adjustments).
    The rear springs will go in a box just in case I am FORCED to do the repair.
  13. #353
    Sep 2008
    Whitestone, NY
    18,499
    OH almost forgot.
    The spare was out of air when I needed it to use to get the car in the back yard as the car was slammed due to the broken front spring. The valve stem on the tire was leaking.....
    Ordered a new one (as it is a funky size) and I am now back in business....hope not to need it.
  14. #354
    37,611
    Leave it to the Germans to use non-standard valve stems.
  15. #355
    Sep 2008
    Whitestone, NY
    18,499
    Yeah tell me about it. I had to go out and buy special tools as well....large hex sockets, e torx, and triple square sockets. WTF!
  16. #356
    I post a lot...
    Mar 2007
    North Las Vegas Nevada
    2,219
    When I had to change valve stems on MBZ rims I never had to go to the dealer to get "special" valve stems for a MBZ.
  17. #357
    Sep 2008
    Whitestone, NY
    18,499
    Quote Originally Posted by Rodentkiller View Post
    Nor did I for the four driving wheels. The spare in the other hand requires a special uncommon size.
  18. #358
    Sep 2008
    Whitestone, NY
    18,499
    Attempted and succeeded at replacing the rear springs....third times the charm I guess in my case.
    This time I followed this lead: https://forums.mbclub.co.uk/threads/...2#post-1879821
    It is a bit sketchy but it did work and my rear springs are replaced!
    The compression plates holding tight to the first rear spring I removed:
    Old springs out...getting crusty looking down at the bottoms...
    New springs in
    Sitting pretty
    If this method did not work I would have attempted dropping the sub frame as that would have been my only option left as the lower a arms bushing were seized at both ends. Doesn't matter now...Job is done. No fear of it breaking on me.
    Attached Thumbnails Attached Thumbnails IMG_2051.jpg   IMG_2052.jpg   IMG_2053.jpg   IMG_2054.jpg
  19. #359
    37,611
    I hate springs and spring compressors. They make me very nervous. Single best thing about air suspension, releasing stored energy is simple and safe.
  20. #360
    Sep 2008
    Whitestone, NY
    18,499
    I agree. Definitely need to be cautious. I did feel safer with this style as the spring really couldn't go anywhere. While handling it though I was weary if it would explode in my grasp.
