Could be bad u-joints. Does the car seem to clunk when shifting into gear?
Need help
stuff at that low of a speed is usually more of a flat or high spot on a tire sort of problem than a U joint issue. Not impossible though if the U joints are extremely bad.86 Lincoln Town Car (Galactica).
yeah... I'm betting on the near bald tires. Buddy of mine had a bad vibration on his exploder and it was a front tire with a blister. got a used tire swapped on that was actually round and the vibration went away.
ive never seen different color check engine lights in any ford ive ever owned I got a 95 grand marq LS with a 281 in it and my check engine light is orangish yellow or I guess a light red depending on light conditions in the pass compartment I believe ford engine lights are orange anyway but I got the digi dash in mine too so .......... check engine lights come on for the stupidest reasons in order to get mine to turn off I had to change my air filter go figure that one out ol
well, you're kind of right. The light that reads "Check Engine" is amber. There is also a red light on boxes that just says "Engine". Not all boxes had the amber computer-driven Check Engine lamp, but the 89- at least all had the red Engine lamp. The red light of doom comes on if you have no oil pressure, or have severely overheated the engine. The amber one comes on if the computer is upset about something. Those two lamps are often confused since they both contain "engine", but mean very different things. Maybe in 1990 they did away with the confusing lights and went with a red lamps that told you something specific, rather than just you need to replace the engine.Last edited by gadget73; 06-15-2014, 07:42 PM.86 Lincoln Town Car (Galactica).
Checked EGR vacuum line and it seems good... possibly a bad EGR? oh and would a code 34 make the engine over rev before shifting.. that's what i am talking about with it feels like a late shift
Originally posted by gadget73 View Post63 says you have a problem with the TPS. Its probably bad, or the tab inside has broken. You can verify it with a voltmeter but its probably not lying.
34 means the EGR valve isn't opening. It may be a cracked vacuum line between the valve and the control solenoid.
98 means the engine off test didn't pass. Change the TPS and fix the EGR valve issue so that you get a code 11 with the engine not running, and this should go away.
the TV cable being a dink tight might cause over-revving (gotta "drive hard" to get it to shift cause it wants to rev high before shifting), but if you're talking about it shifting and spinning up in the middle of the shift, that's probably worn out clutches/plates in the trans and in need of a rebuild/shift kit.
Originally posted by gadget73 View Postwell, you're kind of right. The light that reads "Check Engine" is amber. There is also a red light on boxes that just says "Engine". Not all boxes had the amber computer-driven Check Engine lamp, but the 89- at least all had the red Engine lamp. The red light of doom comes on if you have no oil pressure, or have severely overheated the engine. The amber one comes on if the computer is upset about something. Those two lamps are often confused since they both contain "engine", but mean very different things. Maybe in 1990 they did away with the confusing lights and went with a red lamps that told you something specific, rather than just you need to replace the engine.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Originally posted by extortion00 View PostChecked EGR vacuum line and it seems good... possibly a bad EGR? oh and would a code 34 make the engine over rev before shifting.. that's what i am talking about with it feels like a late shift
34 wouldn't have anything to do with shifting. Maybe TV cable adjustment would.86 Lincoln Town Car (Galactica).
I dropped the Transmission pan today and replaced the filter with some new fluid with a half quart of Bar's Leak 2 part transmission repair.. didn't really change anything.. going to give the TV cable adjustment tomorrow any good write ups on how to do this? btw it's more of a high rev that holds unless you give it more gas then it shifts.. even worse with the A/C on
that sounds like the TV cable is too tight (probably by 1mm)
