Wheel Help Needed
    Wheel Help Needed
    Will these wheels fit an 89 Colony Park without any issues?
    Wheel Diameter: 17 in.
    Wheel Width (in): 9.000 in.
    Wheel Material: Steel
    Primary Wheel Color: Gray
    Wheel Finish: Matte
    Manufacturers Wheel Series: Wheel Vintiques 62 Series
    Backspacing (in): 5.125 in.
    Offset: +3.00mm
    Wheel Construction: 2-piece
    Beadlock Functional: No
    Beadlock Included: No
    Lug Nut Seat Style: Conical seat - 60 degree
    Hub Centric: No
    Center Cap Included: No
    Valve Stems Included: No
    Wheel Bolt Pattern: 5 x 4 1/2 in.
    What about tire size?
    245/45ZR17's and the second set have 275/40ZR17's
    You may need a spacer in the front but I doubt it. Other than that, I'd just say 245/45 is probably not going to fit/look decent on a 9 inch
