Looking at adding 2 10s or 8s to my wagon. Just wondering where you guys are putting them? Is there enough room under the plastic panels on the sides to put some bumpage?
Subs
The wheel wells are behind that plastic panel(where the speaker is) so there isn't much room.
I was trying to get a hold of an extra set of trim panels to make some fiberglass enclosures for 8" subs but that hasn't gotten very far.1989 Country Squire - Twilight Blue, 347 stroker
Subs
Hate to grave dig threads but....
I just installed a Kicker Hideaway under the passenger front seat. It's small enough to not get kicked by passengers and it's really good for its small size. Amazon has a refurbished version for $150.1993 Ford F-150 Flareside - July 2010 - August 2013
2004 Ford Mustang - September 2013 - February 2018
1987 Mercury Colony Park GS - August 2015 - Present
2018 VW Golf GTI - February 2018-February 2021 (was a lease)
2003 EZGO TXT - March 2015 - May 2019 (it's road legal!)
2019 VW Golf Alltrack company provided April 2019 - Present
2012 Fiat 500 5 speed - January 2021-Present
2003 Audi A6 Allroad 6 speed July 2021-Present
I'm guessing you mean this one: https://www.amazon.com/Kicker-Hideaw.../dp/B007LQWSYC
Looks like a stout little bit of kit. Doesn't look any bigger than the amp for my subs. It quite literally could be mounted almost anywhere.
Yeah it's great. Just don't expect it to get really loud. It's been fine for my listening needs. I listen to modern rock, ska, electro swing, 70s, 80s rock.1993 Ford F-150 Flareside - July 2010 - August 2013
Nice way to get a little bottom end without giving up any cargo space. The under-seat area is pretty much a waste anyway, not much but dead fries and loose change is stored there.86 Lincoln Town Car (Galactica).
I have a mid 2000's Ford soft shell owners manual zip up thingie i have adapted to hold CD's when I first got the car back in 2006 that resides underneath the passengers side seat. To be honest, it has been pretty much sitting there since untouched. lol~David~
Originally posted by longroof87 View PostHate to grave dig threads but....
I just installed a Kicker Hideaway under the passenger front seat. It's small enough to not get kicked by passengers and it's really good for its small size. Amazon has a refurbished version for $150.1989 Country Squire - Twilight Blue, 347 stroker
meh. Never had an issue with my amp under the seat in the beater. And it's larger than that speaker housing (manual seat). You still have either side and the area above the speaker to the seat itself. Circulation will still happen.
Originally posted by DerekTheGreat View PostThey say the area under the seat provides HVA/C circulation...1993 Ford F-150 Flareside - July 2010 - August 2013
Before doing a sub upgrade, you must do an alternator upgrade. Its pitiful to not be able to maintain voltage when stopped at a light with the heat and headlights on. It's not only better but also safer if you go with a 3G alternator.
Back in June I installed a '95 Mustang GT alternator and a Painless Performance fox body 3G upgrade. The charge cable is not long enough to route nicely so, you'll need to cut your own. It comes with crimp on connectors and heat shrink so all you need is the cable.
There was a ground wire that I ended up grounding to the housing of the alternator itself because if I went to the battery, I didn't get a charge. I may post pictures once I'm back in town if somebody wants them.1993 Ford F-150 Flareside - July 2010 - August 2013
150W sub runs on a 15 amp fuse typically (20A max). Even the stock alternator can handle that, but as with all 2G alts, best to upgrade to the 3G.
I ran my stocker 2G with my sub for awhile, it was pitiful. When I swapped to a 3G it was a major improvement for soundquality, the sub hit harder & tighter with less impact on the lights. I also installed a 2F capacitor and that helped loads, at least by 75%. I used a charge cable from a 90's Continental, was long enough to go from the starter solenoid past the battery, along the core support and up the driver's side frame rail to the existing harness to then meet the alternator. No splicing or any of that, has a fusible link incorporated right at the eyelet going to the SS. If I had to do it again I'd take two of them and splice just enough length to get me running the wire along the driver's side fender and then meeting up with that harness for a more factory look. As it is now though you can't even tell the swap has been done, looks natural.1985 LTD Crown Victoria - SOLD
