3G swap really is not really expensive, especially if you get one from the wreckers. Also, it is very easy to install, since you originally had a 1G alt. After my episode in december, I should have done it to both my 1G boxes. I already have one waiting to go into GMGT.
85.03 Crown Vic Coupe "CVGT"
Originally posted by Bobcat View PostAhh and there's about an 100ft tire track at the end of my road. Even from a rolling 30mph it'll light up the one legger, in second gear.
Looks good to me. At some point I will have to come out that way to see it.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by marquisman View Post3G swap really is not really expensive, especially if you get one from the wreckers. Also, it is very easy to install, since you originally had a 1G alt. After my episode in december, I should have done it to both my 1G boxes. I already have one waiting to go into GMGT.
Originally posted by P72Ford View PostThat was me, and you know it...
Looks good to me. At some point I will have to come out that way to see it.__________________________________________________
Originally posted by SVT98tIt has air ride. I've disabled it since I've been jacking it up and down.
alternators are easy. hook that shit up already.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postalternators are easy. hook that shit up already.
Now it lost spark while driving down the road tonight. I was slamming on the brakes, because that was making the radio come on and then gently rolled to a stop and it stalled. It cranks and cranks, no spark. Pushed it home with a buddy and started doing a quick check over.
MSD box has power and a ground.
No fuses blown.
Coil isn't getting anything
Jumped the distributor leads from the box and tried to ground the coil, nothing.
Checked my ignition wiring, all seems well
Neutral safety switch wiring looks fine. (I'm going to check that farther tomorrow i guess.)
Kill switch is fine.
I was messing with the starter solenoid wiring at the end of my street and it coughed for a second and then nothing since then.
Yes, it's getting gas.__________________________________________________
did the ignition switch in the column fall apart? Flaky radio goes along with that.
If the I terminal isn't in use on the starter solenoid, it will not have spark when cranking. Make sure you didn't knock that off. Won't affect key-on anything but there will be no ignition power in the start position without that.86 Lincoln Town Car (Galactica).
Well it happened to be that the distributor ate its gear.. "Man all the ignition is working properly, that could only mean... Goddamnit."__________________________________________________
Bummer, any damage to cam?
Originally posted by mitymerc View PostBummer, any damage to cam?__________________________________________________
Flush that engine out nice and good. Never good to have bits of metal flowing around.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
you got the wrong gear. Steel goes with roller cams, iron goes with flat cams. If you lost a gear, it sounds like an iron gear on a steel cam. be glad its not the other way, replacing camshafts is more of a pain in the ass. I'd put the proper steel gear on rather than the bronze. I can't help but imagine it will wear better.86 Lincoln Town Car (Galactica).
I was going to post...bronze?! what uses a bronze gear??-Phil
some poop on distributor gears
http://www.stangtv.com/tech-stories/...t-the-details/
you're not running a high volume pump in that are you ?86 Lincoln Town Car (Galactica).
Originally posted by sxcpotatoes View PostSteampunks, of course.-Phil
