85.03 Crown Vic Coupe "CVGT"
    Dave that is hilarious!! LMAO big time!!
    Dave, Dave, Zack. Logan and now possibly toploader. Yikes. No hitting any other cars with our big ass doors okay.
      Niceeeeeeeeeee!
        Well.
        Put the new shocks in, needs coils front and rear aswell as shocks rear. But it's a start.
        Started tearing apart the 'new' engine, stripped it down to a bare block. Going to clean it with gasoline and see about getting it honed.
        Ordered a kit from Summit including:
        all gaskets, main bearings, rod bearings and rings
        Still need to order:
        Cam
        Intake
        Valley pan kit
        Timing chain
        and need to find a source for GT40P heads.
        Now for random pictures.
        Originally posted by SVT98t
          tudor k9 unit lol
          And that shock was toast.
            tudor k9 unit lol
            If you look close, you can see the two German Shepards in the back..
            The guy driving it was also in a wheel chair, I've seen the car before but I thought it was a four door, until now.
              If you change the springs, save the old ones.
              I'm looking to try some slinky/ clapped out ones in my coupe.
              If you guys are unsure of how to degree a cam... give me a ring when the time comes, and I will come out and teach class.
                I'll save em for you, they're pretty shot from the looks of it.
                You may have to, I was reading that the stock 351 Cam would be better than the HO? Since I tore the engine apart with a buddy, it'd probably be greatly appreciated to have some assistance.
                I'm currently at a cross roads of if I should have the crank polished or just clean it up and put it back in.
                Other than that, the rebuild pack should be coming sometime in the next couple days.
                  Even closer and you can see the chick standing in the front of the store checking the car out. I guess a nice classic car and dog(s) gets the chick's approval nowadays.
                    Or she was staring at the white cop car parked in the middle of the parking lot, staring at the car.
                      Cleaned the 351 thoroughly and then yesterday I cleaned the crank and cam (sliced open every finger on my left hand.. Cranks have sharp points.) I painted the headlight buckets and grill, came out nice and gives the car a more mean modern look. Still needs 88+ nose.
                      Still have to:
                      > De-ring the old pistons, clean them, install new rings.
                      > Clean the lifters, figure out if I'm going to buy new lifters /unlikely/
                      > Solve the problem of which cam I want, I'm pushing towards a Trick Flow Stage 1
                      < Box of gaskets, bearings, rings came, still waiting on box for the freeze plugs.
                      > Order engine paint, paint said engine after being built.
                      > Find GT40P heads.
                      Other random shit that has to be done some time or another.
                      > Fix power antenna
                      > Order coils and shocks for the rear
                      > Maybe order new coils for the front
                      > Order new headlights, I'm planning on going with a plastic housing so I can use bulbs rather than sealed beams.
                      > Source some set of cheapo/used mufflers, don't care what. Just need to quiet the car down. I'll worry about sound down the road.
                      > Take off all the rubber body trim (down the doors and such. 5 piece left. Need to find something to remove the adhesive)
                      Too much stuff to do before I ever even drive the car.
                      Oh yeah and..
                      Cleaned block.
                      Old heads (Need to figure out what I want to do with them...)
                      Cleaned crank and cam. (Anyone wants the cam/heads, feel free to ask.)
                        Nick was telling me about y'all's little adventure to go grab your tudor. Nice score!
                        I'd love to have an aero-box tudor. Gonna do a rear end swap too?
                          Yeah it quite the adventure, especially the 40$ toll.. :\
                          But yes, I'm planning on finding a 92+ low mile Vic rear end probably in fall. I want to be able to reuse the axles and hopefully either have it powder coated or just sand it and thoroughly paint it. Planning 3.55 gears with a Trac-Loc.
                            Did your brother ever swap in the minty fresh rear he had purchased from ez pull? Maybe that is still kicking around, or you get lucky and score one this year?
                              Yeah, we had it in and all set for Scottfest last year. Lol
                              I can't tow a trailer with my car and I know he's taking his challenger down.. So no axle for me this year.
                              Just took this, after 8 coats, the grill is all done.
                                I think they fit in the trunk......
