It's been a while since i've had my Lincoln running and i'm paying for it. I didn't start it for probably 6 months or so and I finally tried with a fresh battery (left it hooked up the whole time ) and it won't crank. It has power like normal but when I try to crank it, it just makes this grinding type noise. It always used to start up just fine so I figured maybe something chewed up the battery cables but I followed them and didn't find any eaten wires. I figured maybe the starter itself froze up so I hit it with a hammer and that didn't help, so I figure it could be the starter went bad.
Is it very likely the starter just crapped out from no use for 6 months? Would the interior lights and fuel pump turn on if the cables were indeed the problem? I'm lost, not good at diagnostics. I'm trying to get it running since I need to drive it up on ramps to get the transmission pan off to get it fixed so it's truly driveable again.
On a side note, i'm going to attempt to fix my transmission. Right now it won't shift into 3rd or 4th and at first I thought the transmission was gone. My neighbor who has an 82 Town Car (painted black with black turbines and red interior) said that it sounds like the shift solenoid since 1st/3rd are on one band while 2nd/4th are on another and if I had lost 2nd and 4th, then it might be toast but it may just be a bad solenoid and could be saved. Does that sound right? I'm no expert especially when it comes to transmissions.
