Maybe a good oil flush (not sure which chemical is the best - maybe Seafoam) and then a slightly heavier oil might work? Better than ripping out lifters if not totally required.
Yup, that's a lifter tick. Or two.
Originally posted by miamibob View PostMaybe a good oil flush (not sure which chemical is the best - maybe Seafoam) and then a slightly heavier oil might work? Better than ripping out lifters if not totally required.
I would feel like a terrible person if I ever let it sound like sly's.89 Grand Marquis GS.
Unless you really KNOW there is a lifter issue it's worth a shot. I always go for the easiest and cheapest solutions first. If you do use a flush just make sure it is totally flushed out before new oil. May take a few oil changes to make sure.
Just turn the radio louder and drive it.... it will run forever like that.2020 Volvo XC90 T6 Momentum (Ice White / Blonde)
Past Panthers
Originally posted by tjc78 View PostJust turn the radio louder and drive it.... it will run forever like that.
Originally posted by miamibob View PostUnless you really KNOW there is a lifter issue it's worth a shot. I always go for the easiest and cheapest solutions first. If you do use a flush just make sure it is totally flushed out before new oil. May take a few oil changes to make sure.89 Grand Marquis GS.
10-30 is plenty heavy. Particularly on cold startup. Remember the higher the cold number the more startup wear there will be.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View Post10-30 is plenty heavy. Particularly on cold startup. Remember the higher the cold number the more startup wear there will be.
Funny story: It was so dry it wouldn't even start when I put it in there, because I was an idiot and forgot to check it because I had no idea what I was doing at the time.Last edited by ootdega; 07-26-2014, 07:19 PM.89 Grand Marquis GS.
Sounds the same as my 88 Town Car. I've had it for 8 years now and the sounds have gotten worse but still quiets down once the engine is warmed up and keeps running without fail.
I'm all for getting out in front of stuff when it comes up, but I really wouldn't lose any sleep over this one.Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
Originally posted by phayzer5I drive a Lincoln. I can't be bothered to shift like the peasants and rabble rousers
Originally posted by ootdega View PostWell apparently it's never totally required. But I'll do anything that'll help.
Out of curiosity (sorry ootdega, your posts always seem to spin up some thought I've been meaning to ask), what does everyone feel about using trans fluid for a very short time to flush out the oil?
they make "engine flush" that doesn't cost much more that has instructions on how to do it. You definitely don't want to run these long with that stuff in the system typically as they can and will clog up an oil filter and oil starvation is a bad thing.
I've done heard of folks using kerosene in oil briefly too to clean it. Don't think I'd do it in some fancy OHC engine but a pushrod smallblock I'd worry less about.
PeteOriginally posted by gadget73For other types of inquiry, more information is required. Please press 4 to speak to a representative who can help you with your question. This call may be monitored for quality assurance purposes.
I've done ATF flushes before, just drain the main oil plug and add 3qts ATF, and let idle for 5-10 mins or so. ATF is really thin and has detergents in it, a little ATF on a rag is actually really good for cleaning grimy stuff like dirty rubber tool handles.Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
Personally I fear doing solvent flushes to a motor. Most of that stuff is mineral spirits and kerosene. If its so shitted up inside with sludge that its causing oil flow problems, just imagine what getting all that to let go at once will do. Pull a valve cover and see what it looks like. If its not sludgey, you probably don't need any high power wash. If it looks like a Jello mold, you've got deeper problems and I wouldn't suggest trying to use a solvent wash anyway.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostPersonally I fear doing solvent flushes to a motor. Most of that stuff is mineral spirits and kerosene. If its so shitted up inside with sludge that its causing oil flow problems, just imagine what getting all that to let go at once will do. Pull a valve cover and see what it looks like. If its not sludgey, you probably don't need any high power wash. If it looks like a Jello mold, you've got deeper problems and I wouldn't suggest trying to use a solvent wash anyway.89 Grand Marquis GS.
