2000 Mercury Grand Marquis. My car runs like it has a miss fire but I do not get any CEL and I don't know what gives? I did try to change all the spark plugs but not all the wires. I wanted to change all the wires until I found out they were individual coil packs at $60 a piece!!
When I was changing the spark plugs, I noticed that there was oil in the coil pack/plug nearest to the oil fill location. I was thinking that it was possibly sloppy maintenance from the oil change place? I found a way to just deal with the feeling of the miss fire and considered it one of those demons that I will never figure out, but it has got to that point now where its just irritating me that I cant figure it out.
Also I believe that I have the crappy plastic coolant cross over tube/intake?? I believe this is so, because one day the miss fire got so bad that it actually threw a code. Turned out it was the rear passenger cylinder (#4 possibly?), so I bought a pack for that cylinder thinking that would fix it. After I started looking at it i noticed that I was leaking coolant from the heater core return. Tried to reinstall the heater core connector, but the threads in the port were stripped out. (I don't know if that description makes any sense.) Long story short, I had to JB weld the heater core connector back into the intake manifold.
So my questions are:
1) Do the grand marquis have a common miss fire problem without engine codes, if so what causes it?
2) Would the crappy plastic intake manifold have anything to do with the oil leaking into the cylinder coil pack near the oil fill?
Any help is greatly appreciated.
