I have a 2005 grand marquis that i recently installed a 270 amp mechman alternator onto and i am having some issues. While parked everything is fine but when i put the car into gear reverse/drive it drops to a lower rough idle, than my voltage drops significantly (down into the mid 12's).It even hesitates sometimes when i hit the gas. . Mechman said raising the idle of the car would resolve this issue since it isn't spinning the alternator fast enough to maintain volatage but i would need a tuner. I understand that the voltage output of the alt. is pcm contolled and i would need an external voltage regulator to ever reach higher voltage then what the pcm sets. But the idle is controlled by the pcm as well and EVERY shop i call tell me they are incapable of raising the idle..Would appreciate any suggestions!!!!!
PMC controlled alternator
Smaller diameter alternator pulley will make it turn faster if that is in fact the only problem
I'd check the IAC to make sure it's working right first.
