Yes I said the to third power.....
OKAY! The car has what I think is pre-ignition or knocking issues, the car runs great...like you can't here the engine...but when you use the kick down or when using first on WOT the car makes a sound that my old black when made... a nasty knocking\rattle noise until it shifts....it just started recently after driving it....before the car was great a acceleration and highway maneuvers but now its as if the car has lost some steam or power...it feels sluggish upon heavy maneuvers... Ideas?? Not the car was sitting for six months and had no gas in the tank...MIL light is on for EGR related reasons gas millage is soso..
Thanks
NEXT!
Car has a loud fuel pump from sitting 6 months....and after a while of driving the car comes filled with a gas smell...and the gas cap was replaced...It's coming from the trunk area for sure, if you lift the truck door you can really smell it!! even when stepping outside and around the back end of the car.
NEXT!!
A\C compressor makes a LOUD clicking noise at all times except when off it sill cycles on and off. The a\c still gets pretty cold...but the evap or drier mounted on the right hand side passenger shock tower area by the RAD over fill area. takes a while to get cold but it doesn't get that cold....not to the point where it's sweating...
NEXT!!!
Coolant leak form back of engine area sometimes it is allot sometimes its a little, the temp kinda bounces a little but not crazy.
Im thinking engine mounts for this one...vibrations in the wheel and at idle you can kinda feel the engine through the cabin area.
And thats all for now...thanks again you guys are awesome!! My mechanic is going to get a work out with this one!
SEB
Thanks
NEXT!
NEXT!!
NEXT!!!
SEB
