Parts needed:
Dorman part # 74809
1/8 vacuum line
1/8 vacuum T
ultra-black or a body grommet with a 1/4 pass through for the vacuum line
Might need:
3/4 heater hose in case you cut something wrong like I did.
Tools:
utility knife to cut hoses
5/16 driver (who uses a flat screwdriver on hose clamps?)
5/16 drill bit (if not using a grommet - if using a grommet, get the right size drill for the size hole the grommet fits.)
handheld drill
There is no actual modification to the vehicle itself except for the hole to be drilled to pass the vacuum line through the firewall unless you know of another place to poke through that doesn't modify the firewall.
First cut the heater hoses about an inch past the angled edge they hang over and attache the bypass valve in-line at that point.
Here's a pic of it installed... not leaking, and in heating position (any position from HI-LO to DEF on the sliders)
Here's a pic in the AC position (VENT to PANEL) in bypass mode:
I drilled the hole above where the vacuum line for the brake release comes in:
and ran that over to the valve as you can see in the images of the valve.
Pull the BLUE vacuum line (may be black with blue stripe on older boxes) and install the T there with a little section of vacuum line and then attach the end of the vacuum line from the firewall to it.
Now the heater core will be completely bypassed in VENT and PANEL/MAX.
How the valve works:
Dorman part # 74809
1/8 vacuum line
1/8 vacuum T
Might need:
Tools:
handheld drill
