For the last six months, the cruise control on my car hasn't worked right. It will begin to hold the speed, but it doesn't do a very good job at it. If a hill comes up, the speed begins to drop and once the speed is 15mph below the target, the cruise control disengages.
So far I know this:
-Horn works
-I swapped the entire cruise control servo + cable from a junkyard car and it did not solve the problem
-The throttle cable may be sticky, but I'm not sure how to tell if it is for sure
-Dump valve seems to be properly seated on the brake pedal
-The symptoms started after a mechanic broke the TV cable while doing the lower intake gasket. Something else may have been broken in the process
What do you guys think?
So far I know this:
-Horn works
