Transmission pan leaking RTV?
    Well I had changed my tranny fluid about 6 months ago and I have been noticing a leak developing on the passenger front side of the pan. I torqued it down to the propper 10-12 Ft-lbs it need and it still does it.
    Only happens if the car sits for over a week.
    I used a rubber gasket and a little gasket rtv stuff to ensure the gasket stays in place.
    A budy of mine told me that I don't need (not suppose to use it-the rtv) just for this reason.
    Did I mess up? Could it be the tranny pan?
    Its looks as though I need to reseal the tranny pan. I don't know, I might buy another tranny pan too.
    Any thoughts on my predicament.
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
    Technically you could just use RTV, but you shouldn't have to. It could be the pan being slightly dented or warped, but you should be able to see it.
    How accurate is your torque wrench? it's possible it's not accurate and you can tighten all the bolts a bit more
      If the pan is aluminum, it's also possible to torque them too much and cause the pan to deform enough to cause a leak.
      Nick
        I bealieve it is aluminum (it's stock) don't think it was ever replaced.
        I do compensate a little more. I am pretty sure I went for 10-12ft-lbs
        Is the pan worth bending back, or is it better just to replace?
          if you have a way to remove the pan and make the mating surface flat again, yes it's worth it, and can be done pretty quick. Couple taps with a hammer with a flat block on the other side can do wonders.
            There's always room for error when torquing nuts/bolts. It's just not an exact science. It all comes down to getting the nut/bolt tight enough for your particular application but not too tight. If you have crud in the threads in a low torque application like this one, that could cause the bolt not to be in far enough even though the wrench says the torque is right. Something simple you can try before pulling the pan is take out the bolts one at at time, make sure the threads are clean (blow compressed air in the hole if possible), and re-torque the bolt you just checked before going on to the next one.
              Yeah, I would have to remove the fluid (drain it) - No clue how many quarts that is. On a side note, since the fluid is still newish, can I reuse it, or just cough up the extra time and dough and pour in new?
              I can try to fix it, I just though it was those things that its cheaper to just replace the pan
                The pan would probably have no more than 4-5 quarts. If you suck the fluid out with a clean tube and hand pump before pulling the pan, then I don't see why you couldn't reuse that fluid (unless you find that, despite changing it, it's already dirty enough that you wouldn't want to reuse it). The big issue is contamination. If there's no contamination, then you're just putting back what was already there. If you have crud on the edge of the pan when you pour the fluid out, you wouldn't want that being put in.
                  Gotcha!
                  I guess this time, I will not use the rtv stuff, and just use the Felpro RUBBER gasket from ROCKAUTO.
                  I was trying to find tranny pans on rockauto, but no dice. I guess I could look for another year PAnther, I am sure they are all compatible if its the AOD
                    Gotcha!
                    I don't see why you're rushing to get a new pan at this point. If you didn't have a problem before you removed the pan, and if you didn't do anything to mangle the pan, and if the rubber gasket wasn't damaged, and if you torqued the bolts in the proper pattern, then it might be nothing more than a bolt not being tight enough. With the rubber gasket, you need a certain minimum tightness for it to seal properly. As long as you achieve that, the gasket should be somewhat forgiving of overtightening or minor irregularities in the pan. I don't see how the RTV would have affected anything.
                      Well someone I work with said never to use rtv with the gasket because eventually, it will just leak.
                      In the six months, I have re-torqued the pan again, still leaks.
                      IIRC, it still leaked (not as bad) before I took the pan off
                      So I have no clue, what I could have possible done to bend the pan (if I did which I doubt). I used the wire wheel (bench wheel) to clean the old gasket crap off the pan- But I can't see that bending anything)
                        Don't believe everything you hear. One of my father's former employees used to say, with all seriousness, things like "The dark flakes that you see in cereal are the result of insects getting into the ingredients". I'm no expert, but I just don't see how using RTV properly could lead to problems. Maybe if there was a big blob of it that was allowed to harden before putting the pan on, but even that might not necessarily cause problems.
                        In any event, since you're already prepared to replace the pan, it couldn't hurt to try to overtighten the bolts a little bit. The upper end of the specified torque is probably a bit conservative anyway. Once you're sure the bolts are torqued to the upper end value, give them a further 1/16 turn. That might be all that you need. If not, then you could possibly try another 1/16 turn. The weak link would be the rubber, so stripping the bolts shouldn't be an issue unless the bolts are really tight.
                          actually, am I even right?
                          Is it 10-12 ft-lbs. I didn't even see it call out that spec in the manual
                            If I see this post later when I get home, I can check. Don't have my EVTMs here at work.
                              I have a Chilton's for 89-98 Crown Vic/Grand Marq that says 107-119 in-lbs, which apparently converts to 9-10 ft-lbs. An online source said 10 ft-lbs. If you're already up to 12 ft-lbs, then you should be cautious. Based on what I just read, the housing is aluminum, and the threads in the housing can strip fairly easily. Stripped threads can be fixed, but I certainly wouldn't want the extra aggravation.
                              The only other option that I can think of short of pulling the pan at this point is finding exactly where the leak is and smearing some kind of suitable sealant over that area. Otherwise, I guess you'd have no choice but to pull the pan.
                              Is it possible that something else is leaking onto that area and making it seem like it's coming from the pan?
