Ok, so you can pick up the plug kit at Summit or hopefully somewhere else (I don't know if ROckauto might have them ( i will look)
I will have to carefully make sure the pan is not bent or tweeked.
But aren't the bolt holes supposed to be bent outward (facing away from the tranny) as to insure a tight seal?
