Page 1 of 2 12 LastLast
Results 1 to 20 of 33
Thread: Parking Brake doesn't work SOMETIMES (works worse on hills/in drive)
    Default Parking Brake doesn't work SOMETIMES (works worse on hills/in drive)
    Okay, so on my '94 Grand Marquis, I like to use the parking brake when I park, especially on a hill. Unfortunately sometimes the pedal just plain doesn't work. Sometimes, especially when its on a hill, or in drive (just testing it, as you know you can't keep the parking brake engaged in drive), the pedal depresses with very little effort and it has absolutely no braking effect. So in an effort to see what was up, I just went outside, and while I was in park, pressed the brake down, absolutely no effort needed and it didn't feel like it was engaging ANYTHING. So I shifted to drive (the parking brake pedal came up with a snap), and the car took off fine. While moving forward at 5 MPH, I slowly pressed down on the parking brake, and it took me almost until the pedal reached the bottom of it's movable area when the I heard a sudden CLUNK coming from the rear tires, and the car started to slow down, eventually coming to a stop. Flipping to reverse and reversing at 5 MPH, I pushed down on the pedal, and it had a lot more resistance than it did before, I pressed down on the pedal and the car came to a halt (again, with that CLUNK in the back) after three clicks down on the brake.
    This is consistent all around, the brake has a hard time engaging while in drive, and is much more effective in reverse. After putting the car back in park, I pressed down on the pedal, and it worked (unlike when I started).
    So what's happening here, and what can I adjust to make it work?
    37,123
    are there any pads left in there? remove the rear rotors and have a look. its not uncommon for the parking brake shoes to delaminate and leave you with just a metal shell. Sometimes the backing plates rust, and the shoe retainers fall out, letting the parts flop around. If they are intact, it may just be an adjustment. It adjusts like normal drum brakes with the star wheel at the bottom to set initial position. If they need replacing, you need to remove the axle shafts to change the shoes.
    I've managed to replace those parking brake shoes without pulling the axles on a 97.
    And the e-brake cable may need adjusting along with the shoes.
    37,123
    for all the bother of it, I'd use it as an excuse to change the diff oil and inspect the axle shafts. Probably takes about the same amount of time.
    20,611
    hmm... I'm actually still running the original pads on my 93. but flat lander and texas' lack of winter worth talking about make for long lasting parts.
    37,123
    pads or e-brake shoes? The shoes should never actually wear out, but the glue lets go sometimes and the friction materials falls off. At that point you're basically SOL and have to replace them if you want it to work.
    20,611
    yeah... wrong word... the e-brake shoes. Rear pads have been replaced twice. Fronts... about 4 times.
    Okay, so let me get this straight. The brake shoes in the rear have different shoes for both the regular brakes and the parking brake, or do they use the same pad? If I had worn out pads, wouldn't that cause a horrible decrease in braking power? Don't get me wrong, I'll Jack it up and pull off the tire and stuff, see what's going on in there, but I'm just hoping I don't need a brake job. Pads on discs are easy. Shoes on drums...not so much. At least I'm not familiar with them.
    Oct 2008
    Buffalo, NY
    4,961
    Quote Originally Posted by AmuletOfNight View Post
    They use shoes inside the rotor for the parking brake, which is a terrible design. Take the caliper off and knock the rotor off, shoes are probably either really badly adjusted, or have separated.
    You don't have to pull the axle to replace them, though I guess it would make it easier.
    37,123
    book procedure calls for pulling the axle. no idea how you'd get them in there without doing it. no room to work. people claim to have done it, but i cant see how.
    20,611
    angle nose pliers. It's a very tight fit, but can be done.
    Okay, I'm officially confused. I pulled the tire off and we have rear disc brakes...but...how? I thought that was an LS model option! Okay, so the parking brake doesn't work with the disc brakes...uh....I'm looking at the outside pad right now and it looks brand new, never used. Could it be my rear brakes haven't worked ever?
    Jul 2014
    Canada
    1,609
    The pads on the rotor are controlled by the main hydraulic system. The parking brake shoes are controlled by the cable. A problem with one would not affect the other. The rear pads should wear less than the front pads, but if there's no wear, then it might be a stuck caliper.
    Okay, so take off the caliper and knock off the rotor, there should be brake shoes in there as well? And an adjuster?
    37,123
    adjuster is on the back side of the plate, should be down at the bottom, accessed through a slot. It may have the rubber plug in there yet.
    Make sure there is friction material on the parking brake shoes before you fool with adjusting them. No point making it tighter if the shoes need replacing.
    Jul 2014
    Canada
    1,609
    Yup. It should look like this:
    http://youtu.be/xejJ0IA3gew?t=3m21s
    I don't necessarily endorse whacking the rotor with a hammer the way they show it. But, someone else did mine, so what do I know. I had let a shop do what was supposed to be a simple brake cable fix, and they discovered the friction material had separated from one of the shoes. They had to pull the axles; but, like gadget said, it was a good excuse for changing the differential fluid, which I probably never would have bothered doing.
    BTW, when the video refers to the adjustment in the caliper, that's different than the adjuster for the shoes that gadget is talking about. AFAIK, the parking brake is basically a drum brake within the rotor, but without the hydraulics.
    20,611
    I use a rubber mallet if I'm saving the rotor and it's being stubborn... or the 4# persuasion and hit the body around the lugs to get the rust to let go. I try to avoid contacting the pad surfaces if at all possible.
    Well I'll be damned. I never knew there could be a drum brake inside the rotor..I tried to tell my dad that and he just out right told me I was nuts and that there was no way it was possible. But I guess it is!
    Well looks like tomorrow I'll jack the car back up and get all the stuff off, see if I can't get it adjusted.
    Do you guys recommend lifting the car by the differential, or no? My dad about flipped at me today when he came home and saw that I had the front wheels chocked and only one wheel raised off the ground (lifted on the frame right in front of the rear right wheel), and then a supported by a jack stand. He said something about damaging the suspension or something.
    37,123
    I lift mine by the diff often. Also never paid much mind to only picking one wheel up. If you aren't leaving it that way for months it won't hurt anything.
    Jul 2014
    Canada
    1,609
    One benefit of raising it by the differential is that the rear control arms don't get subjected to the stresses they would if lifting by the frame. Another is that if you're putting the ass end on jack stands, you only need to do one lift. The car was obviously made to be lifted one wheel at a time since that's how the factory jack works, but I wouldn't leave it like that for long.
    Something that seems odd to me is that the back cover of the differential sticks down enough to get in the way. You don't want to be lifting by the lip of the cover, so why the heck do they make it like that?
