Transmission shudder
    Have seen specs of 8-28 ft pounds which is a PRETTY big range!
      Plug: tighten so it can't leak, but not enough to strip it out
        Whenever I do anything that might require me to look something up, I get both the Haynes and Chilton's manuals from the public library. I don't have them handy now, but the following Autozone page indicates 21-23 ft-lbs around the middle of the page, item 2 under "To install" (though I'm not saying that is indeed the right number):
        http://www.autozone.com/repairinfo/r...96b43f802e69a9
        FWIW, when I did mine, I tightened it without a torque wrench to a depth that I was comfortable with, and it went a lot deeper when I did it to the right torque with a torque wrench. For me, this is one of those things that you want to use a proper torque wrench on.
          It is actually caused partly by the fluid and partly by the accumulator pistons. The stock ones have o rings which leak and don't apply the pressure as evenly.
            Try lubeguard black .one bottle per trans fluid change
              Well guys. Thanks for all your help.
              I changed the fluid, took about 11-12 quarts (oddly enough)
              Shudder is gone!
              You guys are the best!
              -1973 Volkswagen Bus Westy
              -1986 Honda Magna 700cc
              -2011 Subaru Outback
                I tightened the pan down to 80 inch lbs first, then 120 inch lbs
                TC plug 20 ft lbs
                  Shudder is gone!
                  You add lubeguard
                    no, didn't have to ad lubegaurd, just 12 quarts of mercon V Castrol Transmax
                      There should already be enough friction modifiers in Mercon V so no need for Lubeguard.
                        This.
                          The Lubeguard basically converts Mercon/Dexron III into Mercon V. Or it replenishes modifiers in fluid that probably should be changed anyway. Fresh fluid of the right type fixes the problem.
                            This. It's a cheap bandaid you can use while saving up for the possible rebuild if a fluid/filter change doesn't solve it.
                              I was very fortunate but nonetheless glad I did this, I am plenty happy with the shifting. And many thanks to you guys for your endless help!
