Rear Main Seal
    Rear Main Seal
    Going to replace my rear main seal in my 93 302 HO. It's not the valve covers, upper intake gaskets, or oil pan gasket, I made sure of it, and it's a fairly large leak, a drip every minute or two after it is run for 10 minutes or so.
    Seems fairly straight forward, remove driveshaft, remove transmission (t5 in this case) Remove old seal, reassemble in reverse.
    Any pointers or recommended brands? Was thinking the teflon fel-pro.
    I've read a lot of people who have replaced them and had them leak a short time afterwards (mustang owners). That would not be ideal, especially considering the engine is sealed up pretty well.
    t5 has some leaks coming from...somewhere, going to replace those seals as well since i'll have it out.
    -Phil
    the big trick is making sure you do not scratch the crankshaft, and making sure the crank doesn't have a groove in it. If its worn where the seal is, you'll need one of those repair sleeve things and the matching seal. Otherwise there isn't much to it, other than it being physically a pain in the ass to get at. A pick or a screw into the seal will usually get it yanked, just watch where you aim it. If you can come up with a piece of PVC pipe of the right size, it does quite nicely as a driving tool to get it in there square.
    A leak that bad makes me suspect either the seal was put in wrong, or the crank is scratched.
      The way I did it (Engine on the stand, so it would probably be a pain in the ass in your case) was to take the oil pan off and loosen the rear main cap. The seal comes out super easy and goes in just as easy. Of course in your case you'd have to lift the engine and get the pan out, and have a torque wrench and all that shit too. I've also heard (not sure if it's true or not) that sometimes a leak from the rear of seal isn't a leak from the seal at all. Sometimes the oil will seep through the flexplate bolts if the holes are drilled too deep. Like I said, not sure if it's true or not. I made sure to use locktite on mine as extra precaution.
        I have NEVER seen a rear main seal leak on 88-93 HO engine... not saying it can't happen, just saying its very unlikely.
        From my experience, its more likely the rear intake manifold gasket, or the PCV screen on the back of the intake is clogged and PCV valve is popping out and dumping oil on the top of the transmission bell housing.
          https://www.youtube.com/watch?featur...&v=IZBI-0Vz9OY
            +1. My rear lower Intake gasket was puking oil down the bell housing. Cork seal shifted during install years ago for the owner. Nice and dry now . The Pcv screen on my 91 also was choked full and was plugged. Causing more oil run off.
            -Nick M.
            Columbia, SC
              I would agree that its quite rare, but if someone was into it, its not impossible they screwed the seal up. Just make sure it is actually the seal before you get into it.
                Most of my cars have had leaking rear mains. Easy to do when the engines on a stand, loosen the rear cap and replace. In the car is a bit harder. The rear main was leaking on my 89 so when I did the 5sp swap I changed it out. Getting the old one out with out touching the crank is the hardest part. I must have put a small tear in the new seal because it still had a very slow drip. I pulled it out and did it gain using the proper install tool and it was fine ever since, well at least until that engine killed itself. Good thing with the t5 is you can bolt the flywheel on, put the bellhousing back on, throw the starter on, and let the engine run for a while and check for leaks.
                  IIRC I used a "sneaky pete" tool by Lisle, engine in the car, on my lopo engine back in 2000. I bought the wagon due to the leaky seal.
                    Wow, lots of responses!
                    Rellik- that's a great video, it's a good point to put sealant on the flywheel bolts! I have the trans and everything related out. Everything down there is covered in oil so it's hard to see exactly where it's coming from. May try to run it to see, but it doesn't matter since i'm going to replace the rear main and oil pan gasket as well. I'll make sure it isn't leaking by running it after everything is together.
                    May i say that the previous owner was a friggin idiot...so many mistakes and shortcuts, that are all getting fixed!
                    -Phil
                      Doesn't it happen more often than not that we are made to suffer for a PO's fuck ups!!!
                        If there was previous bad work, look real close at the crankshaft for damage before you stick the new seal in. Possible they did something when driving in the pilot bearing or something if a tool slipped.
                        There is a pilot bearing in there, right ? If not, you'll fuck up the input shaft on that trans in a major way.
                          I'm slightly unsure as to the condition, there are some rings, so It's getting the repair sleeve. It has a pilot bearing, it fell out, so I need to figure out how it goes back in. Also a random washer appeared when i took the clutch assy out...have to find out where that goes...
                          -Phil
                            pilot bearing should normally press into the end of the crankshaft. I believe those are just a bronze bushing, so its possible the bearing itself is worn on the outer diameter if it wasn't put in right or something. If its not, probably a few dimples with a center punch to raise some metal to keep it in place would do the trick.
                            Random washer ? WTF?
                              It's an actual bearing with needle type bearings inside, I'll buy a new one. IDK where the washer came from "WTF" is exactly what I said.... I don't see it in any diagrams. Also some earlier ones show springs for the fork while other's do not, I don't think this has any such springs in there. I'm debating whether or not to replace the throwout bearing, it's in OK shape, however the quality is questionable, I don't like throwing money out either.
                              -Phil
