1978 Grand Marquis
    Body work on hood, painting prep for trunk . Cut out some already nasty pieces of vinyl top to prevent rust and grim.
ID:	1284414Click image for larger version
ID:	1284415Click image for larger version
ID:	1284416Click image for larger version
ID:	1284417Click image for larger version
ID:	1284418Click image for larger version
    1979 Marquis creamy goodness
      Got my sandable primer about set...what's a good grit to use? I have heard different things.
        The more metallic the higher the number you want to finish with. I finished with 400 on the solid no metallic red 88 in a single stage paint. Metallics I might go as high as 800. 600 is good overall. You can also start in 400 and progress up.
          You start off coarse and work your way to 400 if you are painting with a solid color base coat. Go up to 600 if it has metallics.
          If you laid it on thick start with 220 dry. Go wet at 400 to 600. Use a block and sand in an x pattern...aka cross hatch. Spray some cheap black paint sparingly over the to be sanded area. It will act as a guide coat and let you know where you sanded and where your highs/lows are.
            Really sound advice thank you gentleman. Popping my cherry regarding painting. Will post finished painting pics for a thorough critique.
              Dont expect perfection if this is your first time. Great way to learn though. Dont get frustrated.
                Your right, some body work, painting....and more importantly experience. Researching about paint mix with hardener and thinner....have a trunk and small areas. Hoping to that the color to is close. The test paint spot-on my fenders seem to be pretty close.
                  Paint mixing is something I have not gotten into yet. I spend a ton on the 2k rattle cans (yes they exist) in primer and clear. I also spend a fortune on mixed cans of paint ready to spray. It is definitely something I want to dive into though as it is so much easier on the wallet.
                    The bar is set low.
                    Whatever I do it's got to be better then spray paint on my driver's door.
                      Ah this reminds me of the days when I was a painters assistant. Mixing colors from base was practically life. Knowing which reducer & hardener to use given the humidity & temp was crucial. Wrath of god awaited if clear sagged or took forever to harden up, or on the flipside, if the paint was too dry or clear too orange peely.
                        Want to mix my paint?
                          Color match it? Nope. Select reducer & mix that? Sure.
                            It went well for my first time. Got some bubbles(could be the hardener/humidity/water) that poked up. Waiting it to fully dry. I assume I could sandClick image for larger version
ID:	1284450Click image for larger version
ID:	1284451 very lightly (?)and recoat with some touch up paint. At least it looks better then that God awful spray paint, should last till I get a proper paint job.
ID:	1284448Click image for larger version
                              Hell yeah. Looks a ton better.
                              Little projects like this give you some experience and eventually you will/may want to paint the entire thing, or something else on a larger scale.
                                Thanks Vic.
                                Your advice on wet sanding the primer definitely helped.
                                For $25 in Bondo and $80 in paint, I will take it. As for those bubbles that popped up, is it ok to sand them out and then use some touch up paint?
