Will an 03-04 marauder grille, and head lights fit an 06 GM?
    Does anyone know if an 03-04 marauder grille and headlights fit a 2006 GM? I like the look of the black grille or is there an aftermarket place that makes grilles?
    Not without swapping to 03-05 GMQ header panel and bumper cover.
      Thank you for the info. I'm new to the GM world so i'm learning a lot.
        Just paint your grille body color, that will give you the Marauder look.
        The headlights would be a bit harder to do and I wouldn't bother.
        The grille alone will be more than enough for the look you want.
        Marauder grills are body color.
