This valve body will fit 93-95 AODE/4R70W ONLY. It might fit late 92 model AODE case, but I have not verified this.
Sonnax pressure regulator valve and increased pressure regulator spring have been installed. The OD regulator spring has been updated to 99 newer (low load) spring.
separator plate has been drilled to Jmod spec;
#1 .160"
#2 .081"
#3 .180"
#4 and #5 . 089"
#6 .125"
#7 .093"
#8 .238"
#9 and #11 .110"
#10 .081
Slot #1 in the separator plate gasket has been opened to .100"
The two holes with red arrows are enlarged to .078", which is supposed reduce/torque converter shudder.
valve body does not include solenoids, but I will include new o-rings to install when you swap yours over. New valve body to trans case gasket and new filter are included.
I can also include, new/updated 1-2 and 2-3 bonded accumulator pistons and springs if needed.
$240 shipped to your door.
$275shipped, if new accumulator pistons are included.
#1 .160"
#2 .081"
#3 .180"
#4 and #5 . 089"
#6 .125"
#7 .093"
#8 .238"
#9 and #11 .110"
#10 .081
