I the cam I put in my 351w calls for a 2800 stall torque converter. Any suggestions would be appreciated. I'm running a aod out of an 85 police car
Budget friendly 2800 torque converter for aod
Edge also has a decent rep..........Road Runner might be another option to look at...........
http://www.edgeracingconverters.com/
http://www.roadrunnerconverters.com/Rodney Tolleson, me at the track.....future drag box racer!
The size of the tc is usually dependant on the amount of stall you desire. I used a b&m on my vic, don't recall the size or advertised stall. As long as it will bolt to your year of flex plate & aod you should be good
Originally posted by 351PoliceVic View PostI've never messed with an aftermarket torque converter, so my question is would a 10 inch converter bolt right up or does size matter
As they get smaller in diameter (usually the stall speed goes up), they use arms outside the converter housing to attach to the original mounting points.
I had a dirty dog 3200 in my coupe; what a great converter.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
