I woke up this morning, bright and early, with a mission: To clean the throttle body on my 1994 MGM, in an attempt to get the throttle to stop sticking when opening from closed throttle. So, thats exactly what I did.
So get up, take a shower, ya-da ya-da, get to the parts store and pick up a soft brush and a can of CRC Throttle Body & Intake cleaner. Come home, pop the hood, and begin the fun.
Step 1: Attempt to remove the vacuum hoses connected to the airbox, succeed, but never fail to slice yourself three ways to Sunday on sharp metal objects when the vacuum hoses suddenly come flying off.
Step 2: While trying to remove the mounting screw for the airbox that holds the airbox in place on the throttle body, drop your 1/2" extension onto the engine block, and say goodbye to it forever (yes, this happened, and I still haven't found it)
Step 3: Curse wildly at the motor because it stole your 1/2" extension
Step 4: Search aimlessly for at least 10 minutes to try to find another extension
Step 5: FINALLY find an extension
Step 6: Remove the mounting bolt for the airbox
Step 7: Remove airbox, watch as rubber holder and hose clamp come flying off the throttle body and falls under the car
Step 8: Retrieve rubber holder and hose clamp from underneath car
Step 9: Look into throttle body, cringe at the sight of pure blackness inside of the throttle body (the back of the throttle plate was PURE black, as well as behind it and in front of it too
Step 10: Spray cleaner into throttle body, choke on the fumes of said cleaner
Step 11: Take brush and brush out ugliness of throttle body
Step 12: Watch as black liquid comes out of throttle body
Step 13: Have your father fly out the door telling you to move the car out of the way of the garage (not going to happen)
Step 14: Attempt to start the car without the airbox, nope nope nope
Step 15: Throw everything back together after finishing cleaning
Step 16: Try relentlessly to get the engine started after flooding it with cleaner
Step 17: Engine is all stumbly and junk
Step 18: Engine smooths out
Step 19: Take it for a test drive, and marvel at the fact that the throttle plate is not sticking
Step 20: Rejoice.
So, mission accomplished, with only a couple cuts, and now I don't have a sticking throttle plate. Sounds good to me!
Step 20: Rejoice.
