Is This a Real Motorcraft IAC?
On the opposite end from the connector should be the Ford Part number stamped on it (the left part of your photo - looking directly at the end). If the part number is not on there I would say you have an issue!
Could be a different manufacturing procedure but does it have the Ford number stamped on the end????
The angled plug says its for an HO engine. Same part, but they angled the plug on the motors that face the other way round. You'll probably need to plug it in before bolting it on, but it should work just dandy otherwise.
Any casting differences may just be a revision, or possibly the original equipment ones got a slightly different casting than the replacement parts. They do that with numbering sometimes. There is a Ford factory engineering number, and then the Motorcraft replacement part number. The spark plugs do that at least. ASWF42C is the factory number, and the replacement number is some number I can't recall.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostThe angled plug says its for an HO engine. Same part, but they angled the plug on the motors that face the other way round. You'll probably need to plug it in before bolting it on, but it should work just dandy otherwise.
Originally posted by miamibob View PostCould be a different manufacturing procedure but does it have the Ford number stamped on the end????1989 Lincoln Town Car
Any casting differences may just be a revision, or possibly the original equipment ones got a slightly different casting than the replacement parts. They do that with numbering sometimes. There is a Ford factory engineering number, and then the Motorcraft replacement part number. The spark plugs do that at least. ASWF42C is the factory number, and the replacement number is some number I can't recall.1989 Lincoln Town Car
Originally posted by AshleyTheGreat View PostAfter some digging, it seemed that it was indeed the Ford number stamped on it. Just threw us off because it didn't have the Motorcraft on it as the current one does. Thanks Bob!
Wells makes a majority of manufacturer sensors, and a lot of sensors you buy now are updated from the original designs to accommodate for known failure points, hence why some tend to look different than the originals you remove.1984 Ford Crown Vic LTD, The Murphmobile (RIP)
Ah, the factory unit I pulled off my car was made by Hitachi and had the Ford logo on it, this unit just has a part number stamped in the circular lid thing. Seems to work like the old one did if not better, since the car isn't stalling while learning it's settings and stuff. We'll see.1985 LTD Crown Victoria - SOLD
Lesson learned on the aftermarket shit. Check for vacuum leaks Derek. I put on a new IAC but it was a random brand and caused me constant high-idle. The surge remained when cold and then I found it spraying TB cleaner all over. Had a busted vacuum hose and once that was sorted, I had no more surge. The high idle remained so I stuck my original IAC back on and the idle dropped to normal. Go figure.
On cold start, my car idles up 2-3 times, vrrrroooom, vrrroooom, vrrrrooom, then drops into a steady, low, normal idle. No surge when put into gear like before, no roughness to speak of, she's just happy. Seriously check for vacuum leaks, thoroughly.
