4R70 valvebody rebuild
    This is for Mike's 2004 MGM.
    I used a valve body core from a 2005 CVPI I had as a core. The stock pressure regulator valve was lightly scuffed and the boost valve and OD regulator shuttle valves were pretty worn.
    I assembled the valve body with the stock pressure regulator valve spring, new valves from Sonnax and a new "Tuff" plate (separator plate) from Superior.
    The new separator plate was drilled to Jmod spec:
    hole 1 = .161"
    hole 2 = .1015"
    hole 3 = .180"
    hole 4&5 = .113"
    hole 6 = .161"
    hole 7 = .089
    hole 8 = not used in this application
    hole 9&11 = .125"
    hole 10 = .089"
    The valve body was reassembled with new gaskets and the bolts torqued to 100 in lbs
