I have a 2000 Grand Marquis and noticed smoke and burning smell coming from the ac vent. AC is still working ok at this point,car is not overheating. Any ideas ?
2000 G Marquis / Smoke and burning smell
If it smells like oil, check the valve covers for leaks. If it smells electrical, you may have a wiring issue somewhere. Check the function of everything to see of maybe something isn't working like the clock or cig lighter or anything else.
If not those issues, could be the heater core spewing clouds of coolant vapor. The smell usually isn't described as a burning smell, and I wouldn't expect a coolant cloud to get through the vent when the A/C is on, but it's something to consider. Check your coolant level to see if it's going down.
Thanks for your replies, I drove it after my wife told me it was smoking I only got a wisp of smoke and a faint odor, not enough to tell. Either something burnt out under the dash or it might be the heater core , I thought of that too. I will turn on the heater and let it idle to see what happens . If not the heater coil, it must be electrical which would mean something shouldn't be working. I'll let you know what I find,may be helpful to someone else .
That was the approach I took with mine. By the time the fall rolled around, the rad developed a leak.
