Page 1 of 13 12311 ... LastLast
Results 1 to 20 of 251
Thread: 1988 Lincoln Town Car
    88 LTC nfldfordltd's Avatar
    Oct 2005
    Conception Bay South, Newfoundland and Labrador
    888
    Default 1988 Lincoln Town Car
    I'll try again to do a little writeup on the nine year adventure that has been my ownership of this car.
    It's an oh-so-blue cloth seat 88 Lincoln Town Car base model. I bought it in summer 2006 for $2500 from a guy who sold it just so his ex-wife wouldn't get it in the divorce settlement.
    At that time it had 127,xxx km (about 79,000 miles), all original parts and paint.
    Here's a brief summary of what was done with it every year up to this year: (excluding oil changes and other 'routine maintenance')
    2006: Inspection for transfer of ownership. That included tie rod ends and exhaust work. Some smog crap eliminated at that time. 4 matching used tires installed as well. All new brake lines. New upper engine gaskets. Swapped over newer parts from the 88 Crown Vic it replaced including alternator and battery.
    2007: Dual exhaust (Cherry Bomb Turbo mufflers) installation. New rotors, pads, calipers, ect. New water pump, radiator, thermostat and housing, all rubber hoses. New power steering lines and stereo head unit. Installed rear springs (1991 Crown Vic RCMP donated), 4 new shocks. 4 new studded snow tires. New voltage regulator connector.
    2008: First new heater core. 4 new tires for summer. Full tune up including fuel filter. New tailpipes as one of the pair used in the dual exhaust conversion was used and rusted out. Remote starter installed.
    2009: Used transmission from when I broke the tail shaft in the original transmission. New drums, shoes, spring kits, disc pads, wheel cylinders, etc. New paint in October at a cost of almost $3200. New battery.
    2010: Heater core #2 went bust. Used clutch fan from a truck 351. All new front end including ball joints, tie rod ends, pitman arm, idler arm, sway bar end links.
    2011: Heater cores #3 and #4 installed. #3 lasted less than a week. Changed rad cap and put heater hose flusher fitting in the hose as well. Popped the block heater out of the frost plug hole (lost all coolant), got very, very hot but still made it home and lived to tell the tale. New Flowmaster 50 Series mufflers. Brass TV cable bushing.
    2012: NOS driver side mirror as the thermometer in the original one was stuck on 18 degrees celcius. NOS hood lift shocks, MAP sensor, other bits and pieces like that. Noticed trunk floor getting rusty, but no holes at this point. Greased the power window regulators in the front doors.
    2013: Another full tune up, eliminated a bunch of unnecessary vacuum lines, replaced a lot of the other ones. Refinished the lacy spoke aluminum rims and installed 4 new RWL tires. New disc pads. K&N air filter. New starter. New front upper control arm bushings.
    2014: Installed Lincoln logs. Punched out the cats and re-installed them with the guts gone. Got NOS stainless steel rain guards and put them on. Put a temporary patch on the trunk floor to provide some rigidity.
    2015: On the road (sort of). Have to cut out and replace the front half of the trunk floor as it is rusted out bad now with big holes and weak metal near the gas tank strap anchor. Also have to replace the gas tank during this operation as the original one has a hole chafed in it from the straps moving. Purchased remanufactured A/C compressor kit (compressor, orifice tube, drier), going to get new lines and condenser ASAP. The A/C will be operational just in time for the hot weather to be over...lol. Also heater core #4 has bit the dust, new one #5 will be installed soon along with new heater hoses and another restrictor for good measure. Needs two new rear tires as well hehe...
    251,xxx km on the odometer as of today.
    Time for some picutres:
    Attached Thumbnails Attached Thumbnails DSC_0367.jpg   IMG_0837.JPG   IMG_0838.JPG   IMG_0839.JPG   IMG_0840.JPG
    IMG_0841.JPG   IMG_0842.JPG   rusty trunk.jpg   tvlinkage-grommet-f3sz-7h303-b.jpg   Lincoln002.jpg
    Summer car-> 1988 Lincoln Town Car, triple blue, 292,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
    Winter vehicle-> 1995 Ford F-250 XLT SuperCab 4x4, 237,xxx+km. AKA "Brutus" 460/E4OD/4.10 axles and 12 MPG. Bought 2019/08/14
    21,547
    Nice. I'd have to pull out my folder of receipts to have any clue on what year what was done to my rides. Too much to list.
    Oct 2005
    888
    Took me a while to recall all that, and I'm sure I missed stuff too...
    I just hope now when I get everything done something major doesn't give out on me, like the engine or rear axle! lol
    fomoco panthers !
    May 2011
    Bangor,Maine
    3,103
    That new paint looks great. Hopefully for the money you paid, the paint shop paid attention to the small details.
    Oct 2005
    888
    Puh no! I had to remove the chrome myself before I dropped it off there.
    I looked OK until I had it shipped from Goose Bay to Deer Lake in 2012. I asked it be but in an enclosed trailer, and the company put it on a flatbed, then hauled it over literally hundreds of miles of gravel highway. That resulted in approximately 200 chips in the paint and broke the windshield in 3 places. Couldn't get a cent out of the trucking company. I was (and still am) pissed.
    I post a lot... 88Vic's Avatar
    Olathe, Kansas
    1,653
    How does it sound with punched out cats? I've heard it doesn't sound as good as replacing them with a smooth pipe. I'm gonna stick with mine but if they start to clog, they'll be gone in a heartbeat.
    Oct 2005
    888
    Quote Originally Posted by 88Vic View Post
    I'm really happy with it, personally. The 50-Series Flowmasters make for a quiet idle but a distinct growl when you get into the throttle. They do kind of act like resonators a bit IMO. I'll try to make a video someday (not today, I have it all took apart to replace the heater core again lol).
    But mind you I have never heard a box with pipe replaced cats so I don't know for sure. My truck has the cats gone altogether and replaced with pipe and it sounds pretty good with cast iron manifolds and regular single round muffler. Nice little chug-a-lug.
    Olathe, Kansas
    1,653
    Since Lincoln logs are harder to find, I figure I can get Mustang shorties a lot easier. Also since my exhaust is still almost new, I'll have a shop make catless downpipes that reduce to 2" and bolt it to my stock H-pipe. Then I'll just have to figure out what mufflers to get if it's too loud with just pipe.
    This is all academic at this point, not sure if I'll keep the car if I can't put a new transmission into it cheap enough. I'll definitely need Mustang shorties and HO intake swap to make the car not such a turd, I'm used to the power of my 4Runner so it'll be hard to go back to such a slow car. I figure those mods and at least a K-code rear will be needed for me to be satisfied with it's performance, for now.
    GMN Regular
    Mar 2008
    Fredericton, N.B. Canada
    12,525
    How much $ are these heater cores that keep failing??
    '79 Continental Town Car
    '90 Crown Victoria LTD
    '94 Crown Victoria
    Oct 2005
    888
    Beauty of Logs is they are direct bolt-on with no fabrication required. But if you have access to a muffler shop that will make the pipes for you then you're all set for Mustang shorties. I think I'm going to do 3.55 rear end gears in mine maybe next year, and do a EFI 351 swap as well if the stars align properly. I honestly can't see a 4-Runner being that much more ballsy than a box (unless it's modified or something) but I guess it's all about how it feels to drive. I'll try to get a video uploaded soon to give an idea about the sound.
    Oct 2005
    888
    Quote Originally Posted by 79lincolnlover View Post
    Roughly $60 each. This last one cost about a little over $100 as I bought new molded heater hoses, all new clamps and had it all shipped here from upalong.
    Coolant isn't very cheap either...lol
    I'm down to under 4 hours work to replace a heater core now after having done it so many times.
    Olathe, Kansas
    1,653
    Quote Originally Posted by nfldfordltd View Post
    It's an 06 with the 4.7 V8 from the Tundra, 270hp/320tq and it's a low-end torque engine because it was designed for use in the Tundra for pulling. It's not the old wheezy V6's, it'll move lol.
    Oct 2005
    888
    Roger.
    Olathe, Kansas
    1,653
    If I can get the local machine shop to attach the stock throttle linkage bracket to the HO TB when I see about boring the stock EGR spacer, I'm gonna do HO upper on mine, hopefully Mustang shorties/catless downpipes and rear end swap, I'm thinking any aero rear for the disc brake and I'll buy new 3.73 or 4.10 ring & pinion and Trac-Loc kit. That should be enough to keep me satisfied.
    And possibly if I can find them in good condition, swap to cloth seats. The leather I have in mine is nice but I remember the cloth seats from my Vic were more comfortable, so I'd like to swap.
    Your list is kinda depressing me, makes me think of all the stuff I need to work on after I get my car running. Stuff like the brakes that I've never touched, all the tune-up stuff, changing the fluids, and installing gauges to keep an eye on stuff and know something's wrong before it's too late. So much work, so little time and money, story of my life.
    Oct 2005
    888
    Didn't mean to get you depressed...but I could have done a bunch of mods to my car and ignored all the basic stuff. I believe in breaking stuff down into two lists: 1. Must do and 2. Like to do. I always take care of the stuff on the must-do list first, then if there's any resources left over (time and/or money) I shift my attention to the like-to-do list. That's why my car isn't nearly as fun to drive as a lot of other GMNer's cars, but I can road trip with relative ease and reliability. I'd like to do Scottfest some year when I can get my life in order enough to do such a long road trip. The joys of living in the North...I could have left a lot of the stuff alone and just let it go, but I want everything to work properly, some may even call me OCD lol.
    Oct 2005
    888
    Heater core # 5 was installed yesterday afternoon. I made up a restrictor for the inlet line (hopefully it's the correct line, the one on the passenger side of the heater core) in the core by cutting a hole in the rubber end cap that came on the new core and put it back on, then slipped the new heater hose on over it. Hopefully this is the last time I have to take all that apart, as the the dash, heater box and plastic cowling along the top of the firewall are getting to be in rough shape from it all being taken apart so many times.
    Next I have to replace the block heater, the section of heater hose from the under-upper intake manifold tube to the water pump on the front of the engine. Then I have to get a trunk floor for it (the one I was eyeing at the junkyard here has been crushed), cut that out and weld the new one in, replace the gas tank (I already have that ready to install), finish up the A/C restoration and get two new rear tires.
    Speaking of tires, any suggestions on what size/type of tire I should get? I know there's a thread on that stuff, and I've been looking around here and there but I haven't been able to make up my mind as to what to get. I'm running new P225/70R15s on the front, I'd like to get something close to the same diameter and a little wider for the rear. P235 series tires seem to only be available for trucks, and I'm not really into that. Open to suggestions.
    Ocd isnt fun at times .I agree on the two list thing. That's how I do mine.
    Sent while thinking of new mods for my 96 TC, using Tapatalk.
    21,547
    I think the inlet is the driver side port on the heater core. The inlet should be the line from the intake and the outlet should be the line back to the pump.
    Oct 2005
    888
    Shit. I'll double check it and change it up if necessary. I started the engine while it was all took apart the weekend and a little bit of steam was coming from the hose on the passenger side so I assumed that was the 'feed' line. I'll double check it and change it if necessary now that the coolant is full.
    Olathe, Kansas
    1,653
    As far as tires, I'd stick with 215/70 for economy, since narrow tires don't have as much road contact so less rolling resistance and they're shorter overall than 225/70 so it's like having lower gears.
    If you want a bit wider for handling, there's 235/60 which is a bit shorter than stock 215/70 but gives you that gearing advantage. Not a lot of tire choice in that size, all I've found is BFG Radial T/A and MT Sportsman S/T. Either of those would work, but since you have those new tires, I'd put them on the back, get as much out of the fronts as possible then replace with 215/70 for a raked look, and smaller front tires that roll easier will turn easier, which is why a lot of hot rod guys use skinny little front tires and fat ones in the back.
    When they all wear out, I'd give 4 of the 235/60's a shot. The raised white letters look cool on an old car too.
Tags for this Thread
