Quick AFCO rear shock question
    Heard good things about this AFCO front shock (http://www.speedwaymotors.com/AFCO-1...7-7,24417.html) in the "Making a box not handle like a box.." thread. What's a good AFCO rear shock to run with this? I'll be running 925 front springs/175 rear springs, if that helps.
    Definitely curious about this too
      First you need to install the springs and measure distance between mounting points of the shocks. Then find a shock that is in mid travel. Car must be on its wheels to measure properly. Many shocks will give extended and compressed length so some math is needed to find mid travel. Some give a mid travel range.
      For the rear another option is available an adapter that allows eye mounts for the upper end so both ends would be like the bottom mount. Doing this eliminates the issue with cutting the top pin mount off to remove the shock.
        Post these kinda questions on that thread. Sot that all the suspension questions are answered in one place.
        Originally posted by SVT98t
          Will do. I made a new thread becuase I didn't want to thread-jack, haha. Moderator(s), please delete this thread. I'll re-post in Bobcat's thread.
