Coach Vinyl Roof Issues
    My 86 GM needs a new vinyl roof. This will be the 2nd time I’ll have to replace it since I’ve owned (2002) the car. It sits outside with no car port year round including the Alabama heat. I have a couple of ideas I’m thinking of trying and looking for advice, or suggestions of other ideas I haven’t thought of trying.
    My first idea is to use VLP to repair/fill in the cracks and repaint the top. This would be by far the cheapest. Not sure how good this stuff works. http://www.amazon.com/Performix-0758...nyl+repair+kit Anyone use this product?
    My next idea is to convert it to a slick top. But having a coach rear window mean more work on top of the already labor intensive glue removal process. Has anyone converted a coach to a slick top? How hard is it? Has anyone converted to a slick top and still keep the coach window in place? Maybe using fiberglass/bondo around the window?
    My final idea is to replace the vinyl. The going price around here for a shop to do it is $750-$1,000, if they can order it from their suppliers. I found some folks on the internet switched to canvas top because they last longer. I’m thinking of replacing it myself, but not sure where to buy the top. Has anyone done their own top? Anyone use canvas? Where do you recommend buying a quality top?
    I went through a prison program the last time I replaced the top and not sure of the quality vinyl they used. If I do replace the vinyl, what do you use to keep lasting as long as possible?
    Any other suggestions/ideas folks have done I haven't thought of doing?
    George Burns
    I have been doing marine upholstery for 10 years, our business has been around for almost 20 years. We have to fix factory issues on $1,000,000+ yachts.
    For the vinyl use a good outdoor or marine vinyl. Find a local supplier, and ask what the recommend. DO NOT PUT ARMOR-ALL ON YOUR VINYL. A good vinyl doesn't need it. The only thing you should put on it is 303 Aerospace Protectant. The best way to extend the life of your vinyl is to keep it out of the Sun, without a carport or something you will be replacing it every few years. A car cover is possible, provided you can keep it from sitting on the vinyl and you have some air movement under it. When a cover sits on vinyl in the sun it causes discoloration from the cover.
      I learned my lesson about Armor All from my 1st vinyl top. With the 2nd top, I was told by the shop to just use soap and water. If I can find a local supplier, they can build the pattern for me? I got the impression these tops come from the factory with the pattern.
      George Burns
        Slick top time. You also have a landau, not a coach roof. A Landau is a half top and a coach roof is a full. (This is assuming the car in your signature that's titled as an 1986 Grand Marquis, is the car you're speaking of.)
        Landau roof to slick tops are easy. I'm going to be probably doing it this summer. I personally think they look a fuck-load better, plus less maintenance.
        IIRC you'll need rear window trim from a slick top, I may be mistaken. Basically you need police car rear window trim. (Could be wrong.)
        Originally posted by SVT98t
          He's probably referring to the rear window. On some, it was frenched in using a fiberglass shell. The tell is no trim around the back glass, the vinyl tucks under. Its not a simple process to slicktop one of those. The shell has to be removed, and there is a bunch of dicking about to deal with all that mess. Much easier to just put it back on.
            Lets say the shell is removed. Can a normal sedan window be put into its place?
              Not sure. There may be some modification to the steel that doesn't let that happen. I've never seen the shell removed to know exactly what lives under there. For all I know, the normal rear glass is already in there and just partly blocked. Or not.
                I'd bet dollars to donuts the rear window is exactly the same under the shell. My vote is to replace with canvas. My 04 has a black canvas top that looks almost brand new and that car has lived outside since day 1. My 89 LTC had a dark blue cloth top that looked good when that car was almost 20 (when I sold it).
                Past Panthers
                  Canvas holds up better than vinyl, but runs about twice as much per yard
                    Not a fan of the canvas look myself. I'm also not much for slicktops or all that other base model stuff that is so popular. You know what they say about opinions though.
                      the rear windows are different for sure
                        But would a landau top car have a shell? I know coach roofs do but I haven't seen a half top with one.
                          Some did, at least on Lincolns. Not 100% sure on the Mercury. The rear window trim is the tell. If its got trim, it doesn't have the shell.
                            Am going to have to address this very same issue on my '84 Towncar. Splits in the vinyl are becoming more numerous, am planning on coating the vinyl roof with Herculiner.
                            I experimented with Herculiner on a large vinyl swatch last fall, left it sitting outside all winter, today it looks just like the day I applied it.
                              Vinyl on my '90 is still fairly supple, but does have some small cracks here and there. What is this Herculiner you speak of?
