Adventures in cam swaps, also, how to fail at same
    So this weekend was an episode in fuckery. John (86Vicky) came down to help me swap the Explorer cam in the Towncar to a Comp XE258 that Pantera77 had hooked me up with like 2 years prior. Everything came apart mostly OK until it was time to extract the cam itself. As the lifters were coming out, things stopped looking promising.
    This is an example of one of the damaged lifters. I have 6 or 7 that are similarly dinked. Honestly didn't count, at this point it needs 16 as far as I'm concerned.
    Here are some shots of the resultant damage to the camshaft:
    Working theory is that when I had the cam gear fall off a couple years back, the cam slid backwards and slammed some of the lifters. The side of the lifter where the axle sits cracked, and the roller wasn't able to run smoothly anymore. Fast forward several years and several miles and this is what happened.
    and an overly-sunny video, just because
    Gonna order a new set of lifters and a new thrust plate and see what that gets me. Cam endplay per the book is 0.0005 to 0.0055, and I'm getting closer to .008. There is a visible wear mark on the thrust plate, and I can believe its .003. If that won't get me in range, then I suppose its new timing set time. The plate is cheaper though, only $7.
    Damn, surprised it wasn't making a bunch of terrible noises.
      Jesus christ. Your roller lifters are acting like flat tappet lifters, lol.
      I suppose that wouldn't make it idle too weird, the lobes weren't destroyed as bad as what some solid lifters do. But uh yeah you should've had some valve train noise..
      What'd the oil look like?
      Originally posted by SVT98t
        Its always had some chatter. Those rockers chattered on the motor with the original lifters and the HO cam and the old heads. When this iteration went together, it still chattered so I figured it was either not having the lifter preload set right, or just the rockers are tired and it made noise. Can't honestly say it made noticeably more noise on Saturday than it did 4 years ago when I put it together. I honestly never would have imagined finding this mess inside the motor when I opened it up. I drove like 260 miles on Saturday with it like that, ran just fine and probably gave me more fuel mileage than it has since I've owned it. The last two tanks have been better than 20 mpg, and this thing has never given more than 18 with any regularity.
          Now that is surprising to find for sure.
          Though the signs lead you to believe all was well with the motor good thing you got the itch to put the new cam in. Who the hell knows where those lifters would have decided to leave you stranded.
            What's really interesting about situations like this is it goes to show how much abuse particular parts can take.
            I'd be interested in putting a PI cam in my 2000 MGM someday. I've read some stuff about various adjustments that have to be done depending on the setup, and I'd prefer not to go through that kind of thing. Does anyone know if replacing an NPI cam with a PI cam would require all the adjustment stuff, or would it be more of a "plug and play" kind of thing?
              Your video doesn't do the cam justice. Here you go mang...
ID:	1277572Click image for larger version
ID:	1277573Click image for larger version
ID:	1277574Click image for larger version
ID:	1277575Click image for larger version
ID:	1277576Click image for larger version
                Thanks. Camera doesn't like direct sun. I was using my painting / baking table. Does real nice to bake the finish on parts, not so much for taking pictures.
                On the upside, I've got plenty of time to get brackets and such painted. Refinished my HO plate today, that came out nice. The rest of the brackets look pretty good too, better than they were by a long shot anyway.
                New lifters and thrust plate are ordered. Melling thrust plate is $7, FMS is $50. Melling ktnx. I did go with the Ford lifters. $12 more than the Summit ones, and they are identical to the original lifters that would have been in here. I don't think the fact that they were Summit brand has anything to do with the failure now that I look at it closer, but for small coin I'll go OEM.
                  wooo... Kustom re-grind
                    You mean "Cams" since a SOHC 4.6 has a cam per head? The advantage is minuscule. My 06 put out 209wrhp at SF last year, you don't want those stocker cams. Aint worth the time.
                    On the upside of your cam tomfoolery, your bearing surfaces look mint! At least those aren't destroyed. OR so one would think.
                      Originally posted by Bobcat View Post
                      You mean "Cams" since a SOHC 4.6 has a cam per head? The advantage is minuscule. My 06 put out 209wrhp at SF last year, you don't want those stocker cams. Aint worth the time. ...
                      Ya, "cams", "cam swap". You know what I mean.
                      I was thinking in the context of a PI intake swap and 04+ CVPI air filter box with the bigger MAF. Does that make a difference? From what I've read so far, you get about as much benefit from putting in the PI cams as you would from replacing the entire heads (which would require 93 octane gas from the increase in compression). I know all of that would require a tune, but from the perspective of just swapping the cams (assuming it would be useful in this context), would it require all the fancy adjustment stuff?
                        I don't think the OHC designs really have any sort of adjustment. There may be some sort of a thrust plate that sets cam end play, but thats likely about it. No pushrods to fool with needing different length, just the cam follower and the rocker arm. That stuff all just bolts in. Torque it till its where it goes and you're pretty much done with it.
                        some quick NPI vs PI head flow numbers I found. Must be correct, they are in the internets after all.
                        .100 – 061 – 060
                        .150 – 089 - 086
                        .200 – 112 - 116
                        .250 – 131 - 141
                        .300 – 146 - 160
                        .350 – 160 - 169
                        .400 – 173 - 176
                        .450 – 185 - 182
                        .500 – 188 - 185
                        .550 – 193 - 186
                        If anyone cares, PI cam specs:
                        0.050 Duration: 200/209 (int/exh)
                        Laft @ Valve 505/531
                        Centerline 114/116
                        LSA 115
                        202/207 @.050"
                        .461"/.466" lift
                        114 LSA.
                        No idea on the intake flow numbers. That might be the magic, PI cams and intake on NPI heads may do OK. Probably have better seat of the pants feel with PI heads tho since the low-mid lift numbers are better, but I would expect lower peak horsepower. Essentially it should be a broader power band with PI heads.
                        Mostly this is just guesswork. The most useful thing I ever did with a 4.6 was remove one.
                          Wow... I'm amazed.
                          I'm curious, what exactly happened when you're cam gear fell off? Were you driving and all of sudden boom clang shabang WTF!? or what?
                            ... The most useful thing I ever did with a 4.6 was remove one.
                            You're making fun of me again, aren't you.
                              Cam gave no fucks and just kept on spinning. Makes me worry a bit less about the surface rust i had on mine when i installed it. Shit probably just got polished down by now.
