Page 16 of 16 FirstFirst ... 6141516
Results 301 to 313 of 313
Thread: 1983 Mercury Grand Marquis 2Dr "GMGT"
  1. #301
    fomoco panthers !
    May 2011
    Bangor,Maine
    2,347
    Quote Originally Posted by Grand Marquis GT View Post
    Took me 8 months to find it. 25 bucks shipped!
    The seller did not know or care what he had. You got a good deal.
  2. #302
    GMN Founder Grand Marquis GT's Avatar
    Nov 1982
    Abilene, TX
    20,347
    Oh, and I have a new steering wheel.
    1983 Grand Marquis 2Dr Sedan "GMGT"
  3. #303
    Nov 1982
    Abilene, TX
    20,347
    Thanks everyone for voting me at POTM! So, I woke the beast for the spring/summer, after fixing a roached coolant hose and charged the battery. I picked up some of this rust encapsulator from the local parts guys, and painted it on. This of course was after a session with the grinder/cup wheel. This seam was starting to worry me, as it Is where the sides of the bulkhead are leaking due to rot. Can't wait to fix that soon (sarcasm). I also replaced a missing lugnut, and cleaned it up a bit (but not too much).
    Took a 25-30 min drive, including some 80mph cruising down the interstate (gotta love Texas speed limits!) and it performed about as well as EEC-III CFI will. She's a gutless wonder!
    Attached Thumbnails Attached Thumbnails Click image for larger version.
ID:	47300   Click image for larger version.
  4. #304
    Vinyl Cheese, Meat Pasty SVT98t's Avatar
    Nov 2005
    Upstate, NY
    4,889
    Get some!!!!
    08 Lincoln Navigator L - 149k
    03 Mercury Marauder- 58,171 miles
    97 Ford Crown Victoria HPP "Tank of Justice III" (TOJ3) - 167k
    Quote Originally Posted by pantera77 View Post
  5. #305
    Nov 1982
    Abilene, TX
    20,347
    Went to Pick N Pull (Dallas West) yesterday. Harvested a complete 88 wiring harness, dostributor, and the complete intake.
    Want to take a guess what I am going to be doing?
  6. #306
    Nov 2014
    Evans, GA
    818
    Swapping from CFI to SEFI? And I would assume you're also going from a Duraspark setup to the TFI module?
    -1987 Grand Marquis Colony Park LS (320K Miles) - The Hideaway & April 2017 POTM Winner
    -1997 Grand Marquis LS (190K Miles) - The Daily Workhorse & March 2015 POTM Winner
  7. #307
    Nov 1982
    Abilene, TX
    20,347
    Correct. Some neanderthal butchered the wiring where the relay connectors were supposed to be, but that looks like a somewhat easy fix. I have been analyzing the wiring diagrams from 88 and 83 and it doesn't look like much has changed.
  8. #308
    drink a beer, grow a beard, cut it, grind it, weld it back His Royal Ghostliness's Avatar
    Feb 2015
    3,013
    Enough has changed to annoy the hell outta you tho.
    Chop the square connector for the '83 trans harness off the one that runs along the cowl, splice the 4-wire grey connector for the '88 harness into the '83 wiring that runs alongside the cowl, you'll be using only three of the four '83 wires, remove the red/blue one as it is all stupidly connected and you have the proper one contained into your SEFI harness anyways. Then plug the entire '88 trans harness into both the SEFI harness and the newly spliced connector. This is the straight-forward part.
    Remove all wiring that operates your A/C, new wires are contained into your SEFI harness, you get the nice feature of A/C compressor cutoff during WOT conditions (it helps). The only wire you'll end up with is a piece of black wire with yellow (hashed) tracer coming out of the firewall, splice that into the green/purple wire of the big round 4-pin black SEFI connector in the ECM vicinity, that's what makes the A/C mess do what it needs to do. In the same connector fat orange wire is your fuel pump power off the relay, splice that into the '83 fat tan wire with black hashed stripes from that funny looking 4-pin brocn connector (again in the ECM vicinity).
    And so on and so forth. Some wire colors will match, most will not, and you'll be splitting the wires from one SEFI connector into multiple '83 connectors and harness branches. Then you'll find out some of the SEFI wires have no equivalent in the '83 harnesses anywhere. For example, your new heated O2 sensors do not have a power supply in the CFI harness, you gotta provide them with one yourself. Make sure you have plenty of steaks to throw on the grill, you'll need them to calm your nerves down. lol
  9. #309
    Jan 2007
    Westmont, New Jersey
    10,085
    Luckily, you don't have to really worry about the trans harness too much. As you have the manual swap. But having it all self contained in one harness will be easier for diagnostic purposes!
    "Vicky" 1986 Ford LTD Crown Victoria LX ..................................."Blue" 1992 Mercury Grand Marquis LS
    Vicky
    Too much stuff to list in my signature...
    Blue
    Mods So Far:
    5.0 HO Swap from 92 Cougar, GT40 Intakes With Remanufactured GT40P Heads, Contour Cooling Fans, Autodimming Mirror With Compass, Frankensteined but fully functional JBL Premium Sound System, Working A/C, Big Front Brake Swap, more mods to come soon!
  10. #310
    Nov 2006
    Dirty Jersey Yo!
    7,581
    Modify it and Coyote Swap Time!!!! LOL
    It amazes me the kind of wiring fixes people do to keep things running. Somebody had the bright idea of Perma-texing my injector connectors after snapping the plastic clips off of them. Had to replace each connector :-/ Baffles me why anybody would go through the trouble of using Permatex when Home Depot sells duct tape at decent prices?
  11. #311
    Nov 1982
    Abilene, TX
    20,347
    Next week Instart the nasty job of cleaning all these parts up. Should be fun.
    I also need to get some electrical contact cleaner and start going through the harness.
  12. #312
    Nov 1982
    Abilene, TX
    20,347
    In six weeks when I am all healed up from surgery, work begins again.
    EFI swap, wheels/tires, and going from there.
  13. #313
    Member Giraffe's Avatar
    Jan 2016
    Wichita Falls, TX
    360
    Looking forward to seeing some progress. She looked pretty nice in person!
    óJohn
    1990 Mercury Grand Marquis LS - getting her back in shape (POTM March 2017)
    1995 Mustang Cobra coupe - keeping it simple
    1966 Mustang coupe - soon-to-be project: no longer buried in junk; out of the garage!
