Think I have found aftermarket Big Brake Kits that will fit the rear axle assembly.
Big rear disc brakes
oooo
definitely share when confirmed
Hopefully some one can answer this. What years did they keep this axle flange style on Panthers. This is a shot of a 87 rear. I know they changed later think same but vertical instead of horizontal.
Bolt pattern is 2.00 x 3.3345 measured with my calipers. Parts a bit rusty so could be off a tad on the length
------------> front of vehicleLast edited by turbo2256b; 05-26-2015, 08:55 PM.Scars are tatoos of the fearless
Going by axle tube flange dimensions any of these should fit.
These are 9" small bearing kits.
Wilwood bolt-on big brake (bbk) conversion kits are designed to provide superior braking performance and a highly detailed appearance over a wide range of domestic and import applications. Ssearch for Search Wilwood Brake Kits
There are also other kits from other companies but haven't found info on their dim for axle offset which is 2.5 on the 87 rear. Some ford rears have a 2 5/8 offset. I did measure a exploder rear that was 2 5/8 offset
"Right Stuff" makes a kit
"SSBC" makes a kitScars are tatoos of the fearless
SSBCs cheepest kit that should fit one again have to call and talk to them
They have several other versions.
You dont even want to know the cheapest Gerling disc kits.Last edited by turbo2256b; 05-26-2015, 10:17 PM.Scars are tatoos of the fearless
I know the brakes from an 03+ sit different than the older. I also know that the flanges are the same from 82-97 at least. Not quite sure about 79-81, don't know what rear is in there. 82 was an 8.5, 83+ should be an 8.8, which is the same housing. If 79-81 is an 8.5, those also should be the same. I don't claim to know what exactly lives on a 98-02 rear.
03+ does give a vented rotor vs the solid, but the calipers sit a bit silly and you have to pull them off to angle them properly for bleeding. As long as you don't mind that, it does work. I have personally seen this installed on Jay's 89 wagon.Last edited by gadget73; 05-26-2015, 11:18 PM.86 Lincoln Town Car (Galactica).
I think the 98 and newer are the same flange as the 87 style but vertical instead of horizontal not sure if the actual dimensions are the same guessing they are as one guy did use the newer brakes but has to rotate them to bleed the calipers.
Fitted up the one of the above Wilwood kits looks like it will work.Scars are tatoos of the fearless
I was hoping to just use these brackets when the time came...I guess maybe not.1989 Country Squire - Twilight Blue, 347 stroker
They work, but the calipers sit at the top, not front and back like the others do. The caliper has to be bled without mounting it to the bracket, otherwise the bleeder isn't all the way at the top.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View PostThey work, but the calipers sit at the top, not front and back like the others do. The caliper has to be bled without mounting it to the bracket, otherwise the bleeder isn't all the way at the top.
Yes, but the axle flanges are 90* off compared to a pre 98, so the caliper sits in a funky way.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Right. On a box or aero they will not sit like they do on an 03. They will sit at the top.86 Lincoln Town Car (Galactica).
