Oil is bad, armor-all is bad. Oil turns rubber to mush after a while. The most I'd do is a rinse with lightly soapy water to remove any dirt and grit.
1988 TC Air Ride Not Working
nope, just the level.
The system is set for a range. Outside that range it either vents or pumps depending on which way. It's basically a 3 way switch. On-Off-On. On in the high position vents. Low position pumps. Off... well... nothing changes if the system is sealed good. At least that's the way it works. It could be a variable resistor for the "level sensor". I've never actually played with one, so I'm not sure which style they used. If it's a variable resistor (more intelligent system), then it goes off a range of values with some overlap between the off state and on states so the system isn't pulsing as you ride over bumps.
Anyway I can fiddle with it so it triggers earlier? If people get into the car it dips a bit but it doesn't operate. Takes a good inch of travel or so to get the thing to want to work and then it pumps back up to where it is supposed to be. I'd like to try to take that "slop" out of the system.1985 LTD Crown Victoria - SOLD
Its not a standard switch or a VR exactly. I think it may actually be a hall-effect sensor.
But yeah, it has a center "normal" range that it can fluctuate in between and it won't really do anything. Most you might try doing is making the lever on the switch shorter so that it takes less suspension movement to trigger the suspension.86 Lincoln Town Car (Galactica).
Also there is a timer involved. IIRC it has to stay out of range for 30 seconds or so before the system will activate either up or down. That is how it is kept form reacting to bumps and the like. So you may want to try and give the system a minute to react after you load up the car. I do that and folks sometimes get impatient, I have heard, 'Really? You must be kidding' when I sit there and don't move the car right away after everyone gets in.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by gadget73 View PostIts not a standard switch or a VR exactly. I think it may actually be a hall-effect sensor.
Originally posted by jaywish View PostAlso there is a timer involved. IIRC it has to stay out of range for 30 seconds or so before the system will activate either up or down. That is how it is kept form reacting to bumps and the like. So you may want to try and give the system a minute to react after you load up the car. I do that and folks sometimes get impatient, I have heard, 'Really? You must be kidding' when I sit there and don't move the car right away after everyone gets in.
I hear the same thing whenever I start my car and let the fast idle go away. "Why aren't we moving?" Sorry folks but I like to let everything get suspended by oil before I put load on 'em. I've got a buddy who even in the dead of winter is putting his car in gear almost before the starter has even finished disengaging with the flywheel, it's cringe worthy.1985 LTD Crown Victoria - SOLD
For the air shocks leveling system, is it normal to "level" or "lower a little bit after hours of sitting?"To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
Yes03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
The system must have changed greatly when they went to air springs in '90. My '01 will adjust if you add 20 lbs. to the weight in the trunk, and will also adjust with even the lightest passengers. Also according to the manual it will adjust when you go over bumps and during certain driving conditons. Also as far as leaking down goes my car has sat for 5 days at a time and has not leaked down any that I can discern.
Yeah, you 90+ guys got REAL air suspension. If only Ford would've put air bags on all four corners. I would only trade my 88 for a nice Mk. VII or 1990 TC.. The real stuff like you have shouldn't leak at all, if it does there's something wrong. Us box people got cheap air shocks but we still like to say we have "Air ride" even though its a BS claim haha. You should see the level sensor, it's crude looking, sorta looks like the thing in your toilet lol.1985 LTD Crown Victoria - SOLD
Even the 03 changes height after a while. Always did. Perhaps it is to take the weight off the air springs during periods of inactivity?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
