HO reverse waterpump rotation?
    Hello,
    If I buy a clutch fan or water pump for a 89 Mk 7 HO block or a 90 Mustang HO block, do they need to be reverse rotation water
    pump or reverse rotation fan clutch?
    Would a LOPO water pump or fan clutch work with an HO block?
    Can I bolt up a HO Mustang fan and fan shroud to a 90-91 Grand Marquis?
    I'm looking into purchasing a fan clutch specified for an HO police 5.0.
    Thank you,
    Mike
    Depends on the accessories. If you have the panther accessories, use a panther water pump. If you have the HO accessories, use the reverse pump.
      You use the water pump that goes with your accessories. Just make sure the pump holes match up with the timing cover. I have no idea why, but the Mark VII timing cover has holes the same direction as we need. It should be wrong for the Mark VII, but whatever Ford did, it manages to work for both. Some trucks had an opposite facing timing cover, and that just won't work.
      The fan clutch from a Fox car will probably not work though. You want stock boring panther stuff if you have the stock accessories. The fox pump will definitely not work with panther accessories. Runs backwards, and the flange on it is at a different depth and has a different bolt spacing than the panther stuff has.
        Can you find standard rotation water pumps in aluminum nowadays? I had to go cast iron on mine
          you can, but its the light duty one with 2 less bolt holes and I think it also has a smaller impeller.
            This is depressing, why don't our cars just use cool shit like the mustangs? I love my Fords but every one of them I've owned has given me the opportunity to cuss ford at least a few times a year. WTF were they thinking? When I had the '98 I thought, why the shit did they de-tune a mustang engine for a heavier car and then put everything on it backward? Guess it's just always been that way huh? Fuckers....
              honestly I couldn't give a real answer to that. Why they decided that the intakes needed to face the opposite way or why they needed to have completely different accessory drives is not something that makes sense to me. I know they don't really change over since the plumbing and battery locations are different, but why they started it with the batteries on the opposite sides to begin with is confusing. Seems they could have made it more standard without a lot of work.
              The de-tuned engine may have been for torque reasons. The torque peak on the non-HO is much lower, so you can get by with a lot taller rear gearing and still get your highway fuel economy out of it.
                Yeah I can kinda buy the torque thing I guess, but the rest of it really seems ill-conceived. I also get a kick out of reading posts I've made when I've had a few drinks, I am hilarious! Some would disagree but it entertains the hell out of me.
                  So would swapping to the serpentine belt system off a mustang or Aftermarket will work on the panther using the reverse W/P? I have thought of doing this to clean up the front of my engine.
                  Tim
                  2000 Ford Crown Victoria
                  89 Lincoln town car: RIP
                  1990 Mercury Grand Marquis LS
                    Am also interested in this. I reckon the biggest problem would be the a/c lines.
                      Stolen from another forum, mustang related, but depending on cover you may have interference from a bolt when using a reverse rotation water pump with a standard rotation timing cover. And passage direction is really the deciding factor to what pump you NEED to use as well. [attachments didn't attach]
                      Alex.
                        Thanks alex, every bit of information helps on this. Once we get my brother's mustang out of storage and I have ready access I can get some more useful knowledge on the HO stuff.
                          That chart on the covers isn't really accurate. For some odd reason at least some foxes and panthers have the same timing cover, even with different rotation water pumps.
                          http://www.grandmarq.net/vb/showthread.php?50219
                            yeah, I don't quite get that either. The timing cover on my car came from the '88 Mark VII the block came out of. It is functionally identical to the original '86 Towncar cover, though the Mark VII did indeed have a backwards-ass water pump. My 91 Mark VII has the same cover and the same backwards water pump. I have seen that other timing cover on trucks though.
                              My canadian 91 merc has the correct timing cover for the sting reverse rotation water pump although the angle that the elongated D shape holes are at, are a little different. 5 minutes with the die grinder on the new pump and timing cover matched things up as the actual round holes themselves lined up, just the ramping into the timing cover was a little different. The plate between the pump and timing cover just has the 2 holes anyways so I opened them up swell to cool the beast lol.
