Cragar*
These are a direct fit for 79-02's
I ran these on the HPP Box for less than a day before I blew the diff up, these tires hook up very well! Under 10 miles on them, still have the nubs present. Wheels fit perfect, even with speedway lowering springs I had no rubbing issues. They obviously won't work with the 04 frame, and while I planned to run them on my 87, I now have a set of saleen 18x9's I plan to use instead. Everything's mounted and balanced, ready to go, bolt in valve stems, trim rings, and center caps included as well. Only flaw is two of the wheels have very slight scratches from the trim rings (I never put them on the other two)
http://www.summitracing.com/parts/crr-3458912
http://www.summitracing.com/parts/crr-29270-1
http://www.discounttiredirect.com/di...ze.do?pc=40345 (cheapest I can currently find the tires)
(I found the hiding center cap in the trunk, all 4 accounted for)
I'm asking $750 for everything. I have no intentions of shipping these, but I can meet you within reason or bring them to scottfest
