wheel/tire question
    wheel/tire question
    Hey 'All, This is probably in the wrong spot, but I've gotta brag somewhere. Just bought my First MGM; 1987, LS, white-on-white, burgundy interior, everything appears to work for $500. AND I'M HOOKED!!!! Drove a CV as a Police Officer for several years; I "likey" Big Box Cars. I likey ALOT!!!
    1st dumb question: (Many more to follow)
    Will 235x60 R16 mounted on Dayton Wire Rims 16" x 7" wide fit on my new car?
    THANKS, elf!
    Yes. Your speedometer will read a couple mph slow know the highway, but otherwise you should be OK.
      Exactly 2mph slower reading speedo.
      Alex.
        It's just about the same overall diameter, it'll read .5 mph slower.
          Thanks Guys!!!
            Daytons though? Are you sure you wanna go there? Gotta see pics either way but...are you SURE?
              At least he said 16x7, a normal size. Not like the 13" ones some guys run. Actually that size will be an improvement being taller and wider than stock.
                wheel/tire question
                I bought the Dayton wire wheels this morning; 16 x 7. Should have them by 6July2015. Plan to wait a couple weeks and buy some American Classic Low Profile, Whitewall tires; 235x60 16R. Spec sheet says that the new tires are the same road height as stock tires (27") but much wider.
                I hope the wheels and tires will add a touch of class to the car. I LIKE the "GrandPa's Roadcar" look:
                Exterior - clean looking;
                Interior - comfortable with all the bells and whistles;
                Mechanically - up-graded and improved.
                It has to GO, STOP AND TURN... WITH STYLE
                  should look tits
                    Sounds fresh. You've got to share some pics when you get those wheels on. You just have to!
