For years my transmission will neutral out shifting into overdrive but the after the transmission is warmed up it slips but then catches overdrive. I have just been looking around pricing different shops and decided to just have the transmission rebuilt. I wanted to buy the rebuild kit myself because i get a big discount at oriellys but there are two different kits an ".061 reverse friction drum" or " .080 reverse friction drum" How would i now which kit to get? its an 84 GM. Anyone know if they were the same that year? or are there numbers on the transmission?
Aod rebuild
try 88grandmarq. I know he's done a number of AOD rebuilds. He may be able to answer you. Not sure that anyone else here has done any involved trans work.86 Lincoln Town Car (Galactica).
This the kit you want... but it doesn't include a new OD band or filter.
http://www.transmissionpartsusa.com/...-000027002.htm
If you are going to rebuild it yourself, make sure you have a good manual and the specialty tools, like lip seal protectors, clutch spring compressor, snap ring pliers and bar to measure end clearance.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
no idea what you need until you get the transmission apart. The kit I listed comes with clutches, steel plates, gaskets, seal and metal seal rings... it does not include the 2 bands, torrington bearings, accumulator pistons or filter. The filter gaskets are included.
again, if you want to do this yourself, you will need some specialty tools to assemble it correctly, with out those tools re-assembly is next to impossible.Last edited by 88grandmarq; 07-03-2015, 11:06 PM.2003 Town Car Signature - 3.27 RAR, Dual exhaust and J-mod - SOLD 9/2011
These are not DIY's repairs! Without the proper experience and tools I would have someone else do it.
If you have a shop that will do the repairs, with your parts, then that is a GREAT solution!!
Not sure where you're at but Lou over at Accurate Transmissions in Belleville, Michigan does a great job. Charged Ash just over $1,000 to rebuild her AOD and that was us dropping it off and picking it up later. Been over a year and it shifts great, not to mention the adjusted the TV cable properly.1985 LTD Crown Victoria - SOLD
the transgo shift kit for MECHANICAL AOD is pretty much the way to go. It works well.
A lot of places won't use customer-supplied parts because they don't know what exactly they are getting. Ask if they'll do that before you buy the kit, otherwise you may be stuck with it.86 Lincoln Town Car (Galactica).
Well i got a quote for 1000 today. That's with the shops parts. The only problem was the owner said to be there at two and of course wasn't there to check out the car, he gave me the quote over the phone. i really wanted to ask about warranty info and etc... I know the price isn't that bad but i am a kid on a budget and trying to save anyway i can. I am even debating pulling The transmission myself and leaving it off with a transmission guy i quoted before. Decisions....sigpic
See if you can get any feedback from other people who have used the shop. The AOD is sort of bitchy about needing to be rebuilt correctly. its got the most complicated valve body ever put in an automatic transmission and they don't work for shit if its not done right. I know more than a few people who have had fresh rebuilds burn up in short order, or last just barely out of warranty before it quits. The cheapest price is not necessarily your best value here.86 Lincoln Town Car (Galactica).
I see what you're saying, but if i can save a couple hundred in labor by pulling the aod in the garage ill try. Ill let yal know what happens If it happens :P its gonna be weird driving the Marqee with a properly shifting trans. I can tell this one is barely hanging on sometimes 1-2 shifts get stuck in between for at least two seconds before finally dropping into secondsigpic
