Hey, one of the old, dried up window seals (not the dew wipes, but I should probably replace those as well) at the top back corner of the Mark VI started pulling out, when I tried to shove it back up in, a big chunk broke off.
So does anybody know where I can get the rubber/hard window seals for in the channels around the top and side edges of the power window glass? Not door seals, where the window goes up fully closed.
My searching thus far has found the following sites but I don't know which parts to order. I think I found a source for the metal clips as well, link below.
Clips (don't know which style to get but I haven't looked closely at the ones in the door) http://stores.restorationspecialties...rip-fasteners/
there are pages of window channel seals at that site as well, then there's JC Whitney http://www.jcwhitney.com/fairchild-i...c3827d1409u0j1
Then I found a page of universal windshield and channel moldings here http://www.dkhardware.com/universal-...ZC553M0P1.html
I would like to get this done before I start having water intrusion issues. I've already got wind noise from a cracked/missing section up near the forward corner of the driver door window seal. Will probably do new dew wipes and fix the keypad (etc) while in the doors. The passenger windows have stopped going down, so I'll see if that can be freed up, and some of the seat adjustment directions/switches didn't work on the passenger side, so probably need to clean those contacts or change out the switches/joystick while in there. Luckily, the 2 door motors and regulators are readily available via ebay and possibly other places as well.
