surface rust, best way to remove
70 Torino Squire with M code 351 Cleveland 3.00 has Magnaflow mufflers. Hidden headlights and power windows. All original -
for all those cylinder bores and mating surfaces and rod surfaces... I'd say you're screwed without honing/decking/polishing all of that to fresh metal. all rust removers will etch the metal.
To prevent rusting... anything oil. Spray some used motor oil on everything every 3-6 months and it should keep the rust away. Obviously keeping stuff out of the elements will help loads.
You need to have those engines goto the machine shop. No chance. They need to be hot tanked and honed.__________________________________________________
Yep, nice pile of core motors there.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Originally posted by sly View Postfor all those cylinder bores and mating surfaces and rod surfaces... I'd say you're screwed without honing/decking/polishing all of that to fresh metal. all rust removers will etch the metal.
To prevent rusting... anything oil. Spray some used motor oil on everything every 3-6 months and it should keep the rust away. Obviously keeping stuff out of the elements will help loads.Scars are tatoos of the fearless
The shredder at the scrap yard will take care of that too, but if you want to use those engines they need to go for machine shop work. The required surface finish is not something you can get by wiping something onto a rusty surface.86 Lincoln Town Car (Galactica).
Originally posted by turbo2256b View PostChainsaw bar lube works the best to prevent rust after cleaning and machining. It WILL LAST FOR DECADES.
It is a bit thicker than most oil and a bit gooey and stringy. It was designed to cling to metal and displace water. Eventually it hardens up its not easy to remove.
I use it for undercoating some of my rides, blocks, cranks, rods, pistons, pins, cams, lifters, any machine surface, threads, splines.Scars are tatoos of the fearless
