Results 1 to 8 of 8
Thread: surface rust, best way to remove
    Default surface rust, best way to remove
    Hi,
    What is the best way to remove surface rust without having to go to a machine shop?
    Is there anything I can spray on that will remove the surface rust and something to spray on to help prevent rusting?
    Thank you,
    Mike
Name:	motor pics, dogs haircut;facebook pics 8-3-15 523.jpg
ID:	43418Click image for larger version.
Name:	motor pics, dogs haircut;facebook pics 8-3-15 463.jpg
ID:	43419Click image for larger version.
Name:	motor pics, dogs haircut;facebook pics 8-3-15 411.jpg
ID:	43420Click image for larger version.
Name:	motor pics, dogs haircut;facebook pics 8-3-15 447.jpg
    21,616
    for all those cylinder bores and mating surfaces and rod surfaces... I'd say you're screwed without honing/decking/polishing all of that to fresh metal. all rust removers will etch the metal.
    To prevent rusting... anything oil. Spray some used motor oil on everything every 3-6 months and it should keep the rust away. Obviously keeping stuff out of the elements will help loads.
    Do a burnout, pussy. Bobcat's Avatar
    Jan 2013
    West Granby, CT
    1,268
    You need to have those engines goto the machine shop. No chance. They need to be hot tanked and honed.
    Quote Originally Posted by SVT98t View Post
    Oct 2008
    Buffalo, NY
    4,991
    Yep, nice pile of core motors there.
    Apr 2006
    MI
    3,805
    Chainsaw bar lube works the best to prevent rust after cleaning and machining. It WILL LAST FOR DECADES.
    39,277
    The shredder at the scrap yard will take care of that too, but if you want to use those engines they need to go for machine shop work. The required surface finish is not something you can get by wiping something onto a rusty surface.
    Jul 2014
    Canada
    2,043
    Quote Originally Posted by turbo2256b View Post
    I've been meaning to ask about that. I saw a jug on sale for a relatively cheap price some months ago, but just from shaking the jug it seemed like the oil was the same consistency as motor oil. I was figuring it would be some kind of thick gooey spray-on stuff. Is the runny stuff the right stuff?
    Apr 2006
    MI
    3,805
    It is a bit thicker than most oil and a bit gooey and stringy. It was designed to cling to metal and displace water. Eventually it hardens up its not easy to remove.
    I use it for undercoating some of my rides, blocks, cranks, rods, pistons, pins, cams, lifters, any machine surface, threads, splines.
Tags for this Thread
